Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Torque calculation on a cylinder
Old   June 26, 2019, 10:39
Default Torque calculation on a cylinder
berne is on a distinguished road
Hello everyone,
I have problems understanding the forces function in OpenFoam 5.x.
My simulation contains a Taylor-Couette flow with a rotating outer cylinder and I want to know the torque on the inner cylinder. Therefor I am simulating a quater of the cylinder and use the forces function on the inner wall patch.
Now to my questions:
1. is the moment calculated by the function the torque I want?
2. how do I have to understand the three coordinates of the moment? Do I have to calculate the magnitude?
3. Is it possible to calculate the torque on a whole axis instead of a single point? (the function calculates forces in the z axis which are several magnitudes smaller, but also irrelevant)
I would be grateful for every help and idea.
berne is offline   Reply With Quote
Old   June 28, 2019, 05:20
Zander Meiring
yambanshee is on a distinguished road
The three directions are the torque in each Cartesian axis.
So the first value given is torque around the x axis. The second value is torque around the y axis, etc
yambanshee is offline   Reply With Quote
Old   June 30, 2019, 04:37
Thank you for your answer.
With this definition the results I receive do not make any sense. I would expect a torque on the z-axis which is the axis of the cylinders. But the calculated torque form OpenFOAM on the z-axis is negligible small whereas the values for the x and y axis are pretty similar and correlate with the values obtained by the rheometry calculations.
Do you have any explanation for this?
Old   July 1, 2019, 04:50
Zander Meiring
Without knowing anything about your simulation, it's hard to say.
What is your physical problem you are trying to solve?
what solver/boundary conditions are you using?
Maybe share your function object file along with a cad model from paraview showing the axis system you're using
Old   July 1, 2019, 09:29
The problem I am trying to simulate is a Coaxial Cylinder Rheometer. Two concentric cylinders, the outer one rotates and on the inner one the applied torque is measured.
I am using the simpleFoam solver with laminar flow. The Boundary conditions are: - symmetryPlane for top and bottom
- cyclic on the sides of the quater
- rotatingWallVelocity on the outer wall (origin ( 0 0 0 );axis ( 0 0 1 );omega 1
- noSlip wall on the inner wall
I hope the information is the one you wanted and the pictures are sufficient.
Torque Calculation in CFD Kamilva Main CFD Forum 6 June 23, 2016 12:34
torque calculation to find efficiency of fan bhanu1810 STAR-CCM+ 5 September 2, 2015 03:58
Torque around moving point (transient calculation) adubois FLUENT 0 March 10, 2014 10:39
Solver and geometry choose for drag coefficient calculation around circular cylinder at large Re lin OpenFOAM Running, Solving & CFD 3 April 16, 2009 10:50
torque calculation sudhakar CFX 15 January 5, 2006 09:08
