July 7, 2019, 14:59 |
wallHeatTransferCoef in OpenFOAM6
Eren
Rep Power: 8 |
Greetings!
I am trying to calculate nusselt number in buoyancy driven flow, I got no luck so far for runtime nusselt calculation( there are great resources in forums and chalmers but all of them are for different versions, or someone was using swak4foam which, I literally have no idea. So if anyone has knowledge on nussel calculation on OF6, I'll be glad.) So, I gave up on run time calculation and use "#include wallHeatTransferCoef" in controlDict so I can calculate Nusselt number it on excel but wallHeatTransferCoeff gives values for all walls(it is a enclosure), so: 1) It gaves same value for all walls(and for all time steps), I doubt thats true, T is not really same and even min and max are the same! So I need to modify something but what? I couldn't find anything on user manual. 2) It is really annoying to process that data, is there any way to get that data for only one wall? Thank you in advance, Eren. Last edited by ErenC; July 7, 2019 at 20:06. |
July 8, 2019, 11:47 |
Eren
Rep Power: 8 |
I should probably add these. Last timestep calculations:
wallHeatTransferCoeff wallHeatTransferCoeff write: writing object wallHeatTransferCoeff min/max/integ(TWall) = 0.000637602, 0.000637602, 6.37602e-09 min/max/integ(BWall) = 0.000637602, 0.000637602, 6.37602e-09 min/max/integ(LWall) = 0.000637602, 0.000637602, 6.37602e-09 min/max/integ(RWall) = 0.000637602, 0.000637602, 6.37602e-09 type wallHeatTransferCoeff; libs ("libfieldFunctionObjects.so"); rho 1.156; Cp 3591; Prl 6.12; Prt 6.12; executeControl writeTime; writeControl writeTime; |
July 9, 2019, 07:45 |
Anton Kidess
Rep Power: 29 |
You can use the 'patches' keyword to restrict the postprocessing to certain patches:
https://github.com/OpenFOAM/OpenFOAM...ransferCoeff.H
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
July 9, 2019, 15:41 |
#4 | |
Eren
Rep Power: 8 |
Left and Right walls are zeroGradient and high temperature BC applied from bottom, it is impossible to have same htcoeff at all patches. |
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 | bjdarrer | OpenFOAM Installation | 7 | August 25, 2020 19:15 |
[OpenFOAM.org] Uninstall Openfoam6 | kerim | OpenFOAM Installation | 4 | May 22, 2020 00:07 |
[OpenFOAM.org] Offline installation of OpenFOAM6 on windows 10 | m5m5kh | OpenFOAM Installation | 3 | February 22, 2019 09:23 |
[OpenFOAM.org] E: can't find package openfoam6 | marf | OpenFOAM Installation | 1 | November 30, 2018 19:25 |
[OpenFOAM.org] Failed to install openfoam6 on Ubuntu 18.04.1 | Gary | OpenFOAM Installation | 3 | October 20, 2018 15:19 |
