Problem with boundary layer - noSlip condition not being respected - OpenFOAM
Like Tree2Likes
  • 2 Post By simrego
Old   July 11, 2019, 16:38
Default Problem with boundary layer - noSlip condition not being respected - OpenFOAM
Vitor Heitor Cardoso
heitorvitorc is on a distinguished road
Dear community,
I've been running a few validation tests comparing numerical methods (FVM, FEM, FDM) for flow through parallel plates. I have the the following setups, which are also attached:
- Flow: Laminar, developed, incompressible;
- Flow through parallel plates -> Length = 1 mm, Height = 0,250 mm, thickness = 20 micrometers)
- Fluid: Water (rho = 1000kg/m³, mu = 0,001 Pa.s -> nu = 1e-6 m²/s)
- Pressure-Driven Flow: Inlet Pressure: 1 Pa ( 0,001 Pa/rho)
When I run the simulation, I have very promissing results in a global analysis. However, when I analyze the behavior of the flow next to the walls, I realize the "noSlip" condition is not being respected.
Does anyone knows what could be resulting this behavior? I was studying about y+ and stuff but I have low understanding about it so far, but I thought y+ stuff were influential only on turbulent flow (I might be terribly wrong).
(I'm sorry for the attachments on the text, but I couldnt upload the files)
Thanks in advance.
Best Regards,
Vitor
#-------------------------- Attached Files---------------------------------------------#
p Dictionary
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Inlet
type fixedValue;
value uniform 0.001;
Outlet
type fixedValue;
value uniform 0;
TopWall
type zeroGradient;
BottomWall
type zeroGradient;
FrontAndBack
type zeroGradient;
U dictionary
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Inlet
type pressureInletVelocity;
value uniform (0 0 0);
Outlet
type zeroGradient;
TopWall
type noSlip;
BottomWall
type noSlip;
FrontAndBack
type noSlip;
fvSchemes
object fvSchemes;
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwind grad(U);
div(phi,k) bounded Gauss limitedLinear 1;
div(phi,epsilon) bounded Gauss limitedLinear 1;
div(phi,omega) bounded Gauss limitedLinear 1;
div(phi,v2) bounded Gauss limitedLinear 1;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
div(nonlinearStress) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
wallDist
method meshWave;
fvSolution
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0.1;
//smoother GaussSeidel;
"(U|k|epsilon|omega|f|v2)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-07;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
consistent yes;
residualControl
p 1e-5;
Ux 1e-5;
Uy 1e-5;
"(k|epsilon|omega|f|v2)" 1e-3;
relaxationFactors
equations
U 0.9; // 0.9 is more stable but 0.95 more convergent
".*" 0.9; // 0.9 is more stable but 0.95 more convergent
checkMesh Results:
Checking geometry...
Overall domain bounding box (0 0 0) (0.001 0.00025 2e-05)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (1.59928e-17 2.1878e-17 -1.73529e-18) OK.
Max cell openness = 2.2343e-16 OK.
Max aspect ratio = 2.95283 OK.
Minimum face area = 1.07169e-12. Maximum face area = 6.31543e-12. Face area magnitudes OK.
Min volume = 1.78608e-18. Max volume = 7.55579e-18. Total volume = 5e-12. Cell volumes OK.
Mesh non-orthogonality Max: 39.3315 average: 9.2241
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.465947 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
heitorvitorc is offline   Reply With Quote
Old   August 14, 2019, 05:14
anonymous
simrego is on a distinguished road
Hi!
It is respected, since noSlip creates a BC as a fixedValue Zero.
You see weird results because you are using the paraFoam -builtin versoin, which can't understand that noSlip BC. If you build your paraFoam properly, it should be good. Check the extension if it is .foam (not correct), or .OpenFOAM (correct).
If you set FixedValue (0 0 0), you can read that case properly with paraview too.
marluc and j_ka like this.
simrego is offline   Reply With Quote
boundary layer flow, noslip
Open boundary condition in OpenFOAM t.oliveira OpenFOAM Running, Solving & CFD 3 December 6, 2017 09:59
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
