February 9, 2020, 08:42 |
problem with gradU
王子阳
Rep Power: 6 |
hello every
I recently want to output the vorticity field during the simulation, what code should i insert the contronDict? i use the openfoam 2.3, i can't find " libs "which in controlDict best wish |
February 9, 2020, 11:57 |
Herpes Free Engineer
Rep Power: 12 |
May be you can use the built-in `vorticity` function object in OF:
Vorticity. Vorticity-2. But I use newer versions, so don't know if it works in OF 2.3.x.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
vorticity openfoa2.3 |
Question on the sequence of grad(U) components | ripperjack | OpenFOAM Post-Processing | 1 | September 18, 2018 12:19 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
