Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Applying strain rate function to fluid phase only
Old   March 6, 2020, 20:03
Default Applying strain rate function to fluid phase only
P Quinn
pquinn is on a distinguished road
Hi everyone.
Im relatively new to OpenFOAM and am trying to investigate two phase non-Newtonian flow, for the purpose of simulating the injection moulding process using interFoam. Recently I created a new function object to calculate strain rate, with the intention of being able to demonstrate the effects of strain rate of different types of non-Newtonian fluids (based on injection polymers). I have now run into a problem however, in that when I run my function it is applied to the whole model and so the scale is thrown off due to the highest shear rates being found in the phase representing air, which I do not care about.
What i am wondering is if there is a way for me to apply this strain rate function to the polymer phase only, and not the air phase?
Thanks for any help that anyone may be able to give
pquinn is offline   Reply With Quote
function object, interfoam, strain rate
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
shear rate and strain rate Lilly FLUENT 1 August 29, 2014 00:46
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
