Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
problem in solving fluent3DMeshToFoam and understanding courant number
Old   March 8, 2020, 20:34
Default problem in solving fluent3DMeshToFoam and understanding courant number
vedha
itachi is on a distinguished road
i have used fluent3DMeshToFoam to create the mesh.
and changed the 0 directory as per the boundary conditions, there were no error in forming the mesh, while doing the postprocessing i got the error. The solver i used is icoFoam.i also tried to reduce the time step but no use the error is the same and i'm not sure how to use fluent3DMeshtoFoam this is my first time using the technique to input mesh from ansys Fluent and i got the error as follow
Create time
Create mesh for time = 0
PISO: Operating solver in PISO mode
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.25
Courant Number mean: 361.928 max: 24602.2
smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.00237241, No Iterations 1000
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.0456688, No Iterations 49
time step continuity errors : sum local = 0.0505461, global = 5.83724e-05, cumulative = 5.83724e-05
DICPCG: Solving for p, Initial residual = 0.173228, Final residual = 8.70596e-07, No Iterations 124
time step continuity errors : sum local = 1.16594e-05, global = 4.54525e-08, cumulative = 5.84179e-05
ExecutionTime = 10.26 s ClockTime = 10 s
Time = 0.5
Courant Number mean: 161.446 max: 6644.71
smoothSolver: Solving for Ux, Initial residual = 0.632821, Final residual = 0.00946253, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.630718, Final residual = 0.00359746, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 0.356938, Final residual = 0.016253, No Iterations 1000
DICPCG: Solving for p, Initial residual = 0.968441, Final residual = 0.0431518, No Iterations 51
time step continuity errors : sum local = 3.95353, global = -0.0550776, cumulative = -0.0550191
DICPCG: Solving for p, Initial residual = 0.168988, Final residual = 9.30204e-07, No Iterations 126
time step continuity errors : sum local = 0.00133669, global = 8.39336e-06, cumulative = -0.0550107
ExecutionTime = 37.44 s ClockTime = 37 s
Time = 0.75
Courant Number mean: 734.944 max: 59448.1
smoothSolver: Solving for Ux, Initial residual = 0.626513, Final residual = 0.0591268, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.624025, Final residual = 0.00527135, No Iterations 1000
smoothSolver: Solving for Uz, Initial residual = 0.635244, Final residual = 0.312497, No Iterations 1000
DICPCG: Solving for p, Initial residual = 0.981377, Final residual = 0.0478388, No Iterations 51
time step continuity errors : sum local = 727.937, global = 1.48593, cumulative = 1.43092
DICPCG: Solving for p, Initial residual = 0.171069, Final residual = 9.38289e-07, No Iterations 124
time step continuity errors : sum local = 0.260373, global = -0.00256976, cumulative = 1.42835
ExecutionTime = 66.68 s ClockTime = 67 s
Time = 1
Courant Number mean: 365109 max: 2.20086e+07
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
#4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
#5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#7 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#8 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#9 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam5/platforms/linux64GccDPInt32Opt/bin/icoFoam"
Floating point exception (core dumped)
itachi is offline   Reply With Quote
Old   May 28, 2020, 09:39
geth03 is on a distinguished road
i don't think that your problem is related to fluent mesh or the executable.
did you execute checkMesh ?
What does it say?
geth03 is offline   Reply With Quote
