Probes function doesn't output to a single file. |
June 26, 2020, 04:37 |
Kosuke Seto
Rep Power: 6 |
I use OpenFOAM7 and performed incompressible analysis using rhoPimpleFoam. After running, I tried to collect data sets of pressure at a specific point from all generated results using probes function. I created a file named "probes" in the "system" directory. Its content is like this. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | ------------------------------------------------------------------------------- Description Writes out values of fields from cells nearest to specified locations. \*---------------------------------------------------------------------------*/ #includeEtc "caseDicts/postProcessing/probes/probes.cfg" fields (p); probeLocations ( (0.03 -0.003 0) ); // ************************************************************************* // Code:
functions { #includeFunc probes } And then, I use the command "rhoPimpleFoam -postprocess". The result is like the attached image. It doesn't output values to a single file, but make many files of each times. I wanna make it a single because I wanna make graphs from it. Best regards for any help. |
September 30, 2020, 06:50 |
#2 | |
Max
Rep Power: 6 |
Hello Kosuke, have you found out how to do it in the meantime ? I'm asking myself the same question. |
October 1, 2020, 01:53 |
Kosuke Seto
Rep Power: 6 |
I'm sorry that I couldn't solve this problem. However, I found that I can make a single file of data sets by using OpenFOAM-v2006 (and others from the series by ESI). |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
