August 6, 2020, 10:05 |
How to run scalarTransport functionObject?
#1 | |
Rep Power: 16 |
I have the solution field of a test case ran with simpleFoam (the windTurbine tutorial, to be precise), and I am running on OFv6. So, this is a steady-state case. I now want to compute a scalarTransport based on the last iteration that I have saved, which in this case is iteration 400. For this, I added the following lines to my controlDict: Code:
functions { BlackCarbon { type scalarTransport; libs ("libsolverFunctionObjects.so"); field s; schemesField U; D 1e-09; } } Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "400"; object s; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // sInlet 1; dimensions [0 0 0 0 0 0 0]; // s can represent any scalar // with any dimensional units internalField uniform 0; boundaryField { inlet { type fixedValue; value uniform $sInlet; } outlet { type zeroGradient; } ground { type fixedValue; value uniform 0; } frontAndBack { type symmetry; } buildings { type fixedValue; value uniform 0; } #includeEtc "caseDicts/setConstraintTypes" } // ************************************************************************* // Quote:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6 Exec : simpleFoam -postProcess -latestTime Date : Aug 06 2020 Time : 15:56:27 Host : "node0853" PID : 17590 I/O : uncollated Case : /home/cenaero/acandael/scalarTransportTest nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 400 SIMPLE: Convergence criteria found p: tolerance 0.0001 U: tolerance 0.0001 "(k|omega|epsilon|s)": tolerance 0.0001 Time = 400 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } No MRF models present No finite volume options present scalarTransport write: smoothSolver: Solving for s, Initial residual = 1, Final residual = 0.0480613, No Iterations 2 End In this case, in my controlDict I specified Code:
application simpleFoam; startFrom latestTime; startTime 400; stopAt endTime; endTime 500; deltaT 1; writeControl timeStep; writeInterval 50; ...is it the way it is supposed to be? I am as well a bit confuse on the fact that scalarTransport solves an unsteady equation, but is nevertheless accessible from a simpleFoam (steady) command.. Anyway, any help would be greatly appreciated!! Thanks a lot, Arnaud. |
August 7, 2020, 04:45 |
The scalarTransport functionObject should be added to a running simulation. It is not a single-step post-processing after the run. You could instead copy your U, phi fields to a new case where you run scalarTransportFoam, although in that case you probably will not have turbulent diffusion. Probably best to start running simpleFoam again from iteration 400 with the scalarTransport functionObject in your controlDict. Then it should have an updated s field at the next writeTime. Cheers, Tom |
August 7, 2020, 06:39 |
Rep Power: 16 |
Thank you for your answer. It does make sense.. To your knowledge, is there any available utility allowing to compute a scalar transport on a converged steady field? Furthermore, if I am not mistaken, scalarTransportFoam and the functionObject scalarTransport are 2 different things (running on the same base code, indeed), no? So, I get that running scalarTransportFoam requires to re-run, but isn't the goal of the scalarTransport functionObject to allow such post-processing action? Thanks a lot! |
August 7, 2020, 08:10 |
scalarTransportFoam was already available long before functionObjects became available. However it was just a post-processing tool. So one needed to have a converged (steady-state) field and then run the solver scalarTransportFoam. When it became a functionObject it allowed much more options as you now also have access to the turbulence fields and it will work with compressible/incompressible/multiphase solvers. But it does not run like the standalone solver. You can still make a similar tool yourself, based on scalarTransportFoam, but my idea would be to just add this single equation to the set of equations you are already solving in the first place and then you have the scalar field that you are after at the end of the simulation. Of course if you want to track the scalar field as it develops, you would probably prefer to make the scalarTransportFoam with all relevant physics. It is not how the functionObject itself now works. That being said, it might be an option to run a transient solver with the scalarTransportFoam functionObject turned on, while you have a frozen flow field, but that would also require some coding I guess. Maybe you can copy the pimpleFoam solver and then just turn off solving the pEqn, UEqn and turbulence field equations? Unless someone else knows about a different solution? Hope this answers your new questions. Cheers, Tom |
August 11, 2020, 03:37 |
Rep Power: 16 |
Hello Tom,
Thanks again for your answer, this clarifies it for me. I did think about adding the transport equation to my solver, I think it might be the way to go. Thanks again, Arnaud |
[OpenFOAM.org] paraFoam Fatal Error upon run | Gallienus | OpenFOAM Installation | 2 | April 14, 2020 19:23 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 06:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 11:20 |
functionObject to control run time | marc.immer | OpenFOAM Programming & Development | 0 | March 25, 2014 10:43 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
