Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Divide a surface quantity by the patch area
Old   August 26, 2020, 21:52
Default Divide a surface quantity by the patch area
Charles McCreary
crmccreary is on a distinguished road
I would like to divide a surface quantity by the patch area.
Specifically, I am using MPPICFoam and calculating particle erosion, Q.
Q is in L^3 (m^3).
I would like to divide Q by the patch area to get a new variable in terms of L (m).
I could modify the particle erosion function to create a new variable, but I would then need to re-run the model.
How can I accomplish this post-processing task either using a post-processing function or paraview?
crmccreary is offline   Reply With Quote
Old   August 28, 2020, 16:08
Charles McCreary
To answer my own question, I accomplished my objective in two ways.
I modified ParticleErosion.C to divide by the cell face area so that I get wall loss due to erosion.
Using the python calculator in Paraview,
inputs[0].CellData['kinematic:Q']/area(inputs[0])
openfoam particle erosion
[OLAFLOW] The OLAFLOW Thread Phicau OpenFOAM Community Contributions 457 March 27, 2024 00:59
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[snappyHexMesh] Bad meshing result on corrugated metal sheet UebertreibeR OpenFOAM Meshing & Mesh Conversion 1 August 19, 2016 04:55
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
