Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamCleanTutorials
Old   September 22, 2020, 03:36
Question foamCleanTutorials
909281 is on a distinguished road
Hi,guys.
I have a little problem, I'm running foamCleanTutorials in opt/tutorials,Is there a problem with my openfoam,When I use it later。
909281 is offline   Reply With Quote
Old   September 22, 2020, 05:14
Petros Ampatzidis
petros is on a distinguished road
I am not quite sure that I understand the question but the foamCleanTutorials just cleans the case, meaning that it removes the solution, mesh and processors in the current case folder. Nothing will affect your OpenFOAM installation.
However, you might want to consider copying the tutorials folder in a run directory. This will reduce your anxiety about deleting something or messing up the files. I don't know which OpeFOAM distribution you are using but for the ESI and Foundation the following will work:
cd $HOME/OpenFOAM/<USER>/
mkdir -p $FOAM_RUN
cd $FOAM_RUN
cp -r $FOAM_TUTORIALS .
Best,
Petros
petros is offline   Reply With Quote
Old   September 22, 2020, 21:18
Default Thanks to Petros
Originally Posted by petros View Post
mkdir -p $FOAM_RUN
cd $FOAM_RUN
Best,
Petros
Bro, thank you very much. I didn't expect to get a reply so soon. I will consider your suggestion carefully.
foamcleantutorials
foamCleanTutorials recovery?! nore5 OpenFOAM Running, Solving & CFD 1 September 1, 2021 01:59
[OpenFOAM] Problems opening wigleyHull case in ParaView Ron de Vos ParaView 18 September 12, 2015 14:46
