Terminating simulation when thermal equilibrium is reached. |
September 4, 2020, 06:47 |
Dan Padrao
Rep Power: 5 |
Hi all,
My case includes two regions (air, block) and I am attempting to terminate the simulation once thermal equilibrium has been reached. I am currently using the runTimeControl function object and have been successful in terminating the simulation when the minimum temperature (using fieldMinMax) remains within a given range and time period and when the initial residual for h is low enough and remains within a given range and time period as well. However, I'd like to be able to stop my simulation using a value more physical than h and something more useful than the minimum temperature (depending on the case, the minimum temperature won't always coincide with equilibrium). Therefore I attempted using fieldAverage to obtain the average temperature of the system and a probe to find the temperature at a critical position within the block. However, I am not able to use either of these in the runTimeControl function object and it outputs an error saying that the field is unprocessed. Does anyone have a solution for this? Or maybe a workaround? I'd really like to be able to use the temperature at a designated point to check whether thermal equilibrium has been reached. Kind Regards, Dan |
November 6, 2020, 02:50 |
Rep Power: 8 |
i think the only way to do that would be adding some code to your solver.
November 6, 2020, 04:25 |
Dan Padrao
Rep Power: 5 |
Thanks, I'll have to try that when I tackle this problem again!
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
OpenFOAM Introduction & Thermal Simulation training courses | thg | OpenFOAM Announcements from Other Sources | 0 | November 28, 2017 02:01 |
MCM modelling and thermal simulation | phurba | Main CFD Forum | 0 | September 9, 2015 11:29 |
Thermal Bridge, Autodesk Simulation CFD | Mahdi-Soheyli | Autodesk Simulation CFD | 0 | June 5, 2014 06:33 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
