Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamToTecplot360
Like Tree36Likes
Old   September 4, 2009, 08:40
Default foamToTecplot360
thomasduerr is on a distinguished road
Hi everybody,
is there already a (maybe preliminary) version of foamToTecplot360 for version 1.6(.x) available?
If one were to write such an application what were the main challenges?
( I am rel. new to OF & C++ but would like to postprocessing things with Tecplot 360 scripts as an alternative to Matlab)
Thanks a lot!
rujia likes this.
thomasduerr is offline   Reply With Quote
Old   December 7, 2009, 18:43
Default OpenFOAM to Tecplot 360 converter note
Scott Rumage
scott_rumage is on a distinguished road
Tecplot,Inc. in conjunction with OpenCFD® is pleased to announce the availability of an OpenFOAM-to-Tecplot data converter application at the OpenFOAM® 1.6.x git repository. http://www.opencfd.co.uk/openfoam/download.html
Steps for installing the converter are:
1. Set your TEC_360_2009 environment variable to the root of your Tecplot360 folder if it isn’t already set.
2. Download the bug fix/patched version from the repository
3. Run Allwmake in the foamToTecplot360 source directory since the TecIO libraries need to be built first.
The converter will work with the following OpenFOAM® results:
- static mesh, multiple time steps
- moving mesh (geometry only changes)
- changing mesh (geometry and topology changes)
- polyhedral cell support
- point values (internal fields)
- point values (boundary fields)
- cell values (internal fields)
- cell values (boundary fields)
- multiple sets of lagrangian data ('clouds') with fields
- outputting a mesh with multiple regions
Please contact Scott Rumage (s . rumage @ tecplot . com) if you have any questions or would like more information about the converter.
OpenFOAM® is a registered trademark of OpenCFD® Ltd., who are the producers of the OpenFOAM® software and owner of the OpenFOAM® and OpenCFD® trademarks.
krishtej23 likes this.
scott_rumage is offline   Reply With Quote
Old   July 15, 2010, 07:32
Default foamToTecplot360 and OpenFOAM 1.5-dev
Steffen
steve is on a distinguished road
Hi everybody,
I have problems compiling foamToTecplot360 on OpenFOAM 1.5-dev. Is there a way to get this compiler running with this OpenFOAM version, too?
Any hints are highly appreciated!
Thanks a lot!
Kind regards,
Steffen
steve is offline   Reply With Quote
Old   August 4, 2010, 19:30
Naveen
vetnav is on a distinguished road
I am also running into the same problem, any help on how to read the .plt files generated by running the command foamToTecplot360
Thanks
Naveen
vetnav is offline   Reply With Quote
Old   October 14, 2010, 16:35
anfho is on a distinguished road
Hi All,
does OF 1.7.1 come with a foamToTecplot360 converter or how do I need to install it? Thanks!
Andreas
anfho is offline   Reply With Quote
Old   October 14, 2010, 16:50
Default foamToTecplot360 for 1.7
Scott Rumage
Andreas,
It is my understanding that the foamToTecplot 360 converter is part of the standard download of OpenFOAM 1.7
Scott
Old   October 14, 2010, 18:10
Retired Super Moderator
Bruno Santos
Greetings to all!
Just in case Andreas's next question is "then where is it?"
  • Where is the binary?
    which foamToTecplot360
  • Where is the source code?
    find $FOAM_UTILITIES -name foamToTecplot360
Best regards,
Bruno
sabiru likes this.
Old   May 1, 2011, 00:21
Default Do you need foamToTecplot360 for 2008
Hyung Min Kim
pius is on a distinguished road
Hi ! everyone
If you want to try modified "foamToTecplot360" for tec360 2008
Please let me know your email address. I will send it to you.
or you can get it at my webpage
pius
pius is offline   Reply With Quote
Old   July 21, 2011, 06:37
R. P.
Rophys is on a distinguished road
I'm using the rhoCentralFoam in the openFoam 2.0. When a tried to use the command foamToTecplo360 it gave me the following error: "command not found". In the others versions I didn't have problems using it. Somebody knows how to solve this problem ?
Cheers.
Rophys is offline   Reply With Quote
Old   July 21, 2011, 16:22
Bruno Santos
Greetings Rodrigo,
The library for Tecplot file handling isn't licensed as GPL, the one used by OpenFOAM. Therefore, OpenCFD has set things right in OpenFOAM 2.0 and has moved this library outside of OpenFOAM's code.
Unfortunately, they left only a little information around for people to figure out for themselves what to do. They wrote on the files README.html and README.org at ThirdParty-2.0.0/x where one can find the tecio library. The idea is to download the given link and unpack it into the folder ThirdParty-2.0.0/x.
Then go back to the main OpenFOAM folder and run Allwmake again and things will get themselves straight.
On the other hand, if you are using the Debian packages of OpenFOAM for Ubuntu/Debian, then things get a bit more complicated. If this is the case, I can write instructions for building the tecio library and foamToTecplot360.
Now, if you built OpenFOAM yourself and if you are feeling a bit lazy, you can use the getter script from here... or better yet, here's what you can run:
foam3rdParty
wget "http://www.openfoam.com/mantisbt/file_download.php?file_id=108&type=bug" -O getTecIO
chmod +x getTecIO
./getTecIO
foam
./Allwmake
Best regards,
Bruno
Old   July 22, 2011, 06:54
Default Thanks
  #11
R. P.
Hi Bruno,
Thank you very much for your information. It was very helpful.
If somebody have the same problem, not forget to execute the command ./Allwmake in the thirdPart and in the openFoam folders.
Cheers
Old   August 20, 2011, 03:39
Jignesh
jignesh_thaker2007 is on a distinguished road
Send a message via Yahoo to jignesh_thaker2007
Hi ! everyone
I m using openfoam2.0.0. so plz tel me how to install techplot for converting data of openfoam
jignesh_thaker2007 is offline   Reply With Quote
Old   August 21, 2011, 15:26
R. P.
Hi...
So, are you using the openFoam 2.0 and you wish convert your results to use the Tecplot ? I this way, use the command foamToTecplot360 after finish your simulation.
Obs.: Tecplot is not free. You need to buy or use one that is available in yoir university or campany.
Cheers.
Old   August 23, 2011, 02:14
Jignesh
Originally Posted by Rophys View Post
Hi...
Cheers.
Thanks
i will try to do this
Old   August 23, 2011, 02:37
Jignesh
Originally Posted by jignesh_thaker2007 View Post
Thanks
I tried but it cant work error like command not found
so
plz help me to solve this problem
what are the steps to convert the data of openfoam to techplot360?
right now i havent install tech plot
but i need data file of openfoam in to .dat or .plt format
so what is the procedure to write data in above format?
i m waiting for ur reply
Old   August 23, 2011, 05:15
R. P.
Now I understand your problem. So, follow the steps that Bruno sad and you will fix the problem.
"The library for Tecplot file handling isn't licensed as GPL, the one used by OpenFOAM. Therefore, OpenCFD has set things right in OpenFOAM 2.0 and has moved this library outside of OpenFOAM's code.
Now, if you built OpenFOAM yourself and if you are feeling a bit lazy, you can use the getter script from here... or better yet, here's what you can run:"
foam3rdParty
chmod +x getTecIO
./getTecIO
foam
./Allwmake
Old   August 23, 2011, 05:48
Bruno Santos
Greetings to all!
OOooohhh... now I get it @jignesh_thaker2007, you could have been more specific with your question on the other threads where you posted...
Here's what you need to do first and follow this to the letter!
mkdir -p $HOME/.OpenFOAM/2.0.1
mkdir -p $HOME/OpenFOAM
cd $HOME/OpenFOAM
#wget "http://downloads.sourceforge.net/foam/ThirdParty-2.0.1.gtgz?use_mirror=mesh" -O ThirdParty-2.0.1.gtgz #old version
#tar -xzf ThirdParty-2.0.1.gtgz #old version
mkdir ThirdParty-2.0.1
wget "https://github.com/OpenCFD/ThirdParty-2.0.x/tarball/master" -O ThirdParty-2.0.x.tar.gz
tar -xzf ThirdParty-2.0.x.tar.gz -C ThirdParty-2.0.1 --strip-components=1
echo export WM_THIRD_PARTY_DIR=$HOME/OpenFOAM/ThirdParty-2.0.1 > $HOME/.OpenFOAM/2.0.1/prefs.sh
wmSET
Now for the second part, which is what Rophys was talking about:
foam3rdParty
chmod +x getTecIO
./getTecIO
 ./Allwmake
Do Allwmake here. Sorry about this... doing more than one thing at a time leads to these kinds of errors
Third part:
mkdir -p $FOAM_RUN
cd $FOAM_RUN/..
cp -r $WM_PROJECT_DIR/applications/utilities/postProcessing/dataConversion/foamToTecplot360 foamToTecplot360
cd foamToTecplot360
sed -i -e 's=FOAM_APPBIN=FOAM_USER_APPBIN=' Make/files
./Allwmake
OK, now it should work!
Best regards,
Bruno
Old   August 23, 2011, 05:54
Jignesh
Originally Posted by wyldckat View Post
Greetings to all!
cd $HOME/OpenFOAM
wmSET
foam3rdParty
chmod +x getTecIO
./getTecIO
foam
./Allwmake
I haven't tested this yet, but it should work as intended.
Best regards,
Bruno
yes sir,
i m doing above procedure right now
thanks sir for ur kind reply
Old   August 23, 2011, 07:21
Bruno Santos
I forgot about a detail on the previous post, which I've edited and added now.
See the new third part, as well as the end of the second part which I've edited.
Best regards,
Bruno
Old   August 23, 2011, 09:54
Jignesh
hiiiiiiiiii sir
sir this process takes long time may be 4 hour because downloading speed is very slow
sir i used openfoam version 2.0.0. & i think above details is for foam2.0.1
so is there any trouble arise?
