January 12, 2021, 19:10 |
Not able to visualize setField result
Deutschland
Rep Power: 5 |
Hey everyone,
I am trying to create my own case file and it has VOF in it. I set the fields using setField. There was no error shown in the terminal when I ran the setFields as you can see below: Code:
sam@LAPTOP-BKEON11O:~/OpenFOAM/OpenFOAM-v2006/tutorials/HullTrial$ setFields /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2006 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _b45f8f6f58-20200629 OPENFOAM=2006 Arch : "LSB;label=32;scalar=64" Exec : setFields Date : Jan 13 2021 Time : 00:54:06 Host : LAPTOP-BKEON11O PID : 687 I/O : uncollated Case : /home/sam/OpenFOAM/OpenFOAM-v2006/tutorials/HullTrial nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading setFieldsDict Setting field default values Setting internal values of volScalarField alpha.water Setting field region values Adding cells with centre within boxes 1((-5.194 0 -7.791) (15.58 7.791 0)) Setting internal values of volScalarField alpha.water End but when I try to visualize the result using paraview, it is not working. The option to see the setField is not coming in the place where " Solid color" is shown in the picture attached below. Capture.PNG Can someone help me with it? I have no clue why I am not getting it. P.S. At first, I could not see the cell array either. so I googled and saw that I had to unselect the "Skip Zero Time". After I did that I could see the cell array options. |
January 12, 2021, 19:20 |
Deutschland
Rep Power: 5 |
this the resultant alpha.water file after running setField.Does this have anything to do with why I cannot visualize the result? Thank you in advance for the help. Kind regards vava10 |
how to make analysis from the result in fluid flow (CFX) ansys workbench 14 | wan11 | CFX | 3 | December 18, 2014 19:25 |
Result output chart | YaX | CFX | 4 | July 10, 2014 18:47 |
bad result output | junarzt | OpenFOAM Running, Solving & CFD | 0 | March 19, 2014 10:40 |
[Q] How to visualize result of simulation | luuhoangthien | OpenFOAM Post-Processing | 1 | October 9, 2013 12:02 |
how to visualize the result | luo | Phoenics | 5 | October 10, 2001 20:37 |
