Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to extract alpha cell data in an area within the domain?
Old   May 12, 2022, 09:17
Default How to extract alpha cell data in an area within the domain?
Akshay
enthusiast is on a distinguished road
Hi, I am using twophaseEulerFoam which is included with multiphaseEulerFoam in OF version 8.
I would like to monitor the phase fraction of gas in water over the time steps, I need to analyze the gas phase fraction at the liquid outlet.
But I don't know how to extract this data for all time steps and average it and save it.
Right now I am only using probe point at a certain point, but this is not reliable as it only considers a single point.
I have attached the cells which I would like to consider.
Thank you
enthusiast is offline   Reply With Quote
Old   May 13, 2022, 15:07
Joachim Herb
jherb is on a distinguished road
You can use a surfaceFieldValue function object applied to a faceZone. For the ESI version of OpenFOAM see: https://www.openfoam.com/documentati...ieldValue.html
(for the Foundation version, the same is possible)
The faceZone can be produced with topoSet.
See also: Integrate volVectorField over cross section / cutting plane
jherb is offline   Reply With Quote
Old   May 15, 2022, 16:17
Akshay
Thanks for your valuable input, I am able to extract the faceZone from faceSet within the domain but when I try to start the solver with surfaceFieldValue included with controlDict, I am getting an error.
Can you please provide your valuable inputs regarding this issue.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      topoSetDict;
actions
        name    internalFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (0.9823 0.0965 0.457) (1.009 0.1403 0.528);
        name    internalfacepatch;
        type    faceZoneSet;
        action    new;
        source    setToFaceZone;
        sourceInfo
            faceSet    internalFaces;
			cellSet    internalCells;
			flip    false;
surfaceFieldValue1
		type            surfaceFieldValue;
        libs            ("libfieldFunctionObjects.so");
        log             true;
        writeControl    writeTime;
        writeFields     true;
        regionType      faceZone;
        operation       areaAverage;
		surfaceFormat   none;
        fields
			alpha.oxygen
The error what I am getting is:
surfaceFieldValue surfaceFieldValue1 write:
--> FOAM FATAL ERROR:
surfaceFieldValue surfaceFieldValue1: faceZone(internalfacepatch):
    Unable to process internal faces for volume field alpha.oxygen
    From function Foam::tmp<Foam::Field<Type> > Foam::functionObjects::fieldValues::surfaceFieldValue::filterField(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, bool) const [with Type = double]
    in file fieldValues/surfaceFieldValue/surfaceFieldValueTemplates.C at line 416.
FOAM aborting
Generating stack trace...
Backtrace:
        ZN10StackTraceC1Ev [0x626c1855+0x25]
                 module: C:\PROGRA~1\BLUECF~1\ThirdParty-8\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
        ZN4Foam5error10printStackERNS_7OstreamE [0x6c30ae5a+0x23a]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
        ZN4Foam5error5abortEv [0x6c0c68b1+0x211]
        ZNK4Foam15functionObjects11fieldValues17surfaceFieldValue11filterFieldIdEENS_3tmpINS_5FieldIT_EEEERKNS_14GeometricFieldIS6_NS_12fvPatchFieldENS_7volMeshEEEb [0x958fb68+0x1d8]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libfieldFunctionObjects.dll
        ZNK4Foam15functionObjects11fieldValues17surfaceFieldValue14getFieldValuesIdEENS_3tmpINS_5FieldIT_EEEERKNS_4wordEbb [0x9591d7f+0x36f]
        ZN4Foam15functionObjects11fieldValues17surfaceFieldValue11writeValuesIdEEbRKNS_4wordERKNS_5FieldIdEEb [0x94b711d+0x9d]
        ZN4Foam15functionObjects11fieldValues17surfaceFieldValue5writeEv [0x939d2cb+0x24b]
        ZN4Foam15functionObjects11timeControl5writeEv [0x6c18a32d+0x2d]
        ZN4Foam18functionObjectList5startEv [0x6c180acf+0x8f]
        ZNK4Foam4Time3runEv [0x6c18ccfd+0x19d]
        (No symbol) [0x472123]
                 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\bin\multiphaseEulerFoam.exe
        (No symbol) [0x4013c1]
        (No symbol) [0x4014f6]
        BaseThreadInitThunk [0x7ffbb2517034+0x14]
                 module: C:\Windows\System32\KERNEL32.DLL
        RtlUserThreadStart [0x7ffbb32e2651+0x21]
                 module: C:\Windows\SYSTEM32\ntdll.dll
Old   May 16, 2022, 09:22
Akshay
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      topoSetDict;
actions
        name    internalFaces;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
        type    faceZoneSet;
        action    new;
        sourceInfo
			flip    false;
surfaceFieldValue1
        log             true;
        writeFields     true;
		surfaceFormat   none;
        fields
			alpha.oxygen
FOAM aborting
Backtrace:
Found the solution for my error, if someone has the same problem. This can help.
HTML Code:
https://www.cfd-online.com/Forums/openfoam-post-processing/238974-facezoneaverage-function-object-does-not-work-field-u-p-etc.html
Volume fields needs to be interpolated to surface fields, I implemented it in controlDict, now the solver is running.
post procesing, twophaseeuelrfoam
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 08:26
Reduce on alpha data vishwesh OpenFOAM Programming & Development 0 September 21, 2017 00:37
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 10:20
injection problem Mark New FLUENT 0 August 4, 2013 01:30
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
