February 8, 2021, 10:11 |
Lagrangian positions file format
Luis Felipe López
Rep Power: 6 |
Hi all
I was exporting some Lagrangian data in OpenFOAM v8 and I wanted to use the position of a particle to initialize another simulation. However, I can't understand the format. The "positions" file shows something like this: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class Cloud<passiveParticle>; location "0.056/lagrangian/kinematicCloud"; object positions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 1 ( (0.214858 0.231858 0.160714 0.392571) 3838 7620 1 ) // ************************************************************************* // Best regards, Felipe. |
February 9, 2021, 14:33 |
Mark Olesen
Rep Power: 40 |
Good luck with that unless you wish to reconstruct your entire mesh information first.
May 4, 2022, 10:05 |
Norbert Riefler
Hi Felipe,
did you find a solution to convert the positions into Cartesian values? And where are the diameters of the particles? Best, Norbert |
May 9, 2022, 03:01 |
Josh Williams
Rep Power: 5 |
This is a common problem with several threads. The most useful one is here I think.
You need to run the functionObject from this GitHub repo to convert from Barycentric to cartesian coordinates. |
cloud, format, lagrangian, openfoam, position |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
