Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Precision loss when post-processing with Paraview
Old   June 15, 2021, 16:58
Default Precision loss when post-processing with Paraview
wildfire230 is on a distinguished road
Hi All,
I am having some interesting issues where I believe Paraview is losing precision with some of my data. A simple way to reproduce my case is to use funkySetFields to initialize two data sets as follows:
setC1
field C1; // Field to initialize
expression "exp(pos().x) + 1.0";
keepPatches true;
variables ();
setC2
field C2; // Field to initialize
expression "exp(pos().x)";
keepPatches true;
variables ();
You can see that I am initializing C1=exp(x)+1, and C2=exp(x).
My domain goes from x = -25 to +25, so that the exponential does become quite large, like 10^10. I am using a write precision of 16. Then, in Paraview, I take C1 - C2 using a calculator filter, and the result contains errors on the order of O(10), whereas if we really have 16 digits of precision, I believe the errors should be O(1e-5) in this case. Am I missing something? Does Paraview's calculator only do single-point precision??
EDIT: Ok, I have narrowed down the issue a bit. It seems that whenever you run "paraFoam", all the fields are loaded as type float. Is there any way to load as type double?? Alternately, is there a way to run foamToVTK and write as type double? It seems like this also defaults to float.
I would greatly appreciate any thoughts.
Best regards.
wildfire230 is offline   Reply With Quote
post processing discrete phase with paraview mighelone FLUENT 3 March 9, 2021 04:34
Bulk mean temperature in ansys post processing user9 ANSYS 2 May 22, 2020 23:25
Automated post processing using CFD Post shreyasr ANSYS 0 January 28, 2013 06:21
[OpenFOAM] is parallel processing available in parafoam for post processing? sachinlb ParaView 1 August 14, 2012 09:52
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
