Getting the quantities of the species as a field for further post processing |
October 6, 2021, 13:19 |
Rep Power: 5 |
Hey all,
I am simulating a chemical reaction with rhoReactingFoam and I want to calculate my rate of conversion. To be able to do so I need a new field with the molar quantities of my species. So far I've only found a way to display the molar fractions. Is there a way to create a new output with the moles of my species? Thanks in advance |
October 6, 2021, 13:36 |
Reaction rates can be obtained in post-processing.
I posted a list of quantities that can be obtained in post-processing in What is Object Registry in OpenFOAM? Item #9 Good luck, D. |
October 7, 2021, 02:20 |
Rep Power: 5 |
Thanks for your reply. Unfortunately I'm not looking for a way to get the reaction rates but the conversion of my reaction system. Do you know a way to do that in OpenFOAM or paraview?
December 20, 2021, 12:04 |
Rep Power: 5 |
Rate of conversion ist defined as
If someone stumbles upon this post in search for an answer: I rewrote the rate of conversion to the following form: To get the massflow of each species I needed to do some post processing (which can be directly added to the controlDict for further cases). To get the overall mass flow I used the post processing functions: postProcess -func "flowRatePatch(name=inlet) postProcess -func "flowRatePatch(name=outlet) This provides me with an overview of my inlet and outlet massflow. To optain the mass fractions of each species I used paraView. As the desired mesh region I checked inlet or outlet respectively and used the integrateVariables filter. There I checked "Divide Cell Data by Volume" property. This outputs the mass fraction of each species in the inlet/ outlet stream. I used the makro feature of paraView to implement all of this in python code, which saves the values over time inside a .csv file for further use. |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
Run time post processing vs Post run post processing | pruthvi1991 | OpenFOAM Post-Processing | 1 | February 19, 2015 14:15 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
post processing unsteady species transport | solomon | FLUENT | 0 | October 25, 2003 17:44 |
