How to calculate racecar downforce distribution |
November 15, 2021, 03:32 |
Anton
Rep Power: 4 |
I'm trying to find more downforce for racecar. All car is one body.
I can calculate overall downforce. But how to calculate downforce on front or rear wheels separately? Or how else can I figure out what is the balance of downforce front\rear? |
November 15, 2021, 04:55 |
Yann
Rep Power: 26 |
You have to separate the parts (either by creating separate stl files or having named surface groups in your stl) in order to create patches for each parts your need to analyze. E.g. front wheels, rear wheels, body, spoiler, etc...
Yann |
November 15, 2021, 08:51 |
Anton
Rep Power: 4 |
Is there really no other way to do it? Its not possible to divide the surfaces into Paraview?
November 15, 2021, 09:49 |
Yann
Rep Power: 26 |
In ParaView you can use the clip filter with different clip types (plane, box, cylinder...) to cut down your surface in several pieces.
In my opinion it sounds more time consuming than running your case with proper surface definition though. Maybe somebody will have a better idea... Cheers, Yann |
How to calculate lift, drag and lift distribution in Star CCM+? | israelcasillas94 | STAR-CCM+ | 4 | November 6, 2020 08:35 |
calculate friction factor & nusselt number | soheil1991 | FLUENT | 3 | March 11, 2017 09:30 |
Diameter distribution, Search for options ?! | souria | FLUENT | 0 | January 22, 2016 08:38 |
Small wiggles in pressure distribution | Rouven | Pointwise & Gridgen | 5 | August 29, 2015 11:51 |
How to calculate spread parameter in Rosin-Rammler model | PEGAH | FLUENT | 1 | April 8, 2015 19:02 |
