Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
forceCoeffsIncompressible writes to multiple files
Old   March 25, 2022, 18:36
Default forceCoeffsIncompressible writes to multiple files
Andrés
AndresP is on a distinguished road
Hello everyone,
I'm having trouble with the postProcess utility (OpenFOAM .org v7). I have an already simulated transient case and would like to compute force coefficients for each timestep. I have a forceCoeffsIncompressible dictionary with the corresponding parameters set in my /system directory. I'm running the postProcess utility through:
pimpleFoam -postProcess -func forceCoeffsIncompressible
My understanding (unless I'm remembering incorrectly) is that I should get a single forceCoeffs.dat file in the /postProcessing/*/forceCoeffsIncompressible directory, with the coefficients for each timestep tabulated. However, the utility writes multiple files named forceCoeffs_*.dat , where * is the time associated with the coefficients in the file. Each file has the correct format but only one row in that table I refer to. For example, for forceCoeffs_1.005.dat:
# Force coefficients
# liftDir           : (0.000000000000e+00 1.000000000000e+00 0.000000000000e+00)
# dragDir           : (1.000000000000e+00 0.000000000000e+00 0.000000000000e+00)
# pitchAxis         : (0.000000000000e+00 0.000000000000e+00 1.000000000000e+00)
# magUInf           : 8.300000000000e-01
# lRef              : 3.500000000000e-02
# Aref              : 1.940000000000e-03
# CofR              : (3.000000000000e-01 3.000000000000e-01 8.000000000000e-02)
# Time              	Cm                  	Cd                  	Cl                  	Cl(f)               	Cl(r)
1.005               	-6.941911664379e+00	9.463867864485e-02	9.457727060475e-01	-6.469025311356e+00	7.414798017403e+00
Only the row for t=1.005s is written.
Am I doing something wrong or is this how the utility normally works? I have spent quite some time looking for a solution on the Internet but so far I've found nothing, even on these forums.
I'd like to get a single forceCoeffs.dat with the coefficients for each time one under another (i.e. tabulated). Could someone point me in the right direction? I'd appreciate it.
Regards,
Andrés
AndresP is offline   Reply With Quote
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Calculating YPLUS and Compiling Multiple C files sanjibdsharma OpenFOAM Programming & Development 1 August 11, 2009 06:56
Multiple .res files in animation Gloria Gaynor CFX 5 April 6, 2009 19:36
Evaluating multiple fluent files Ralf Schmidt FLUENT 0 October 25, 2004 05:15
