Sampling a limited number of points using cuttingPlane |
August 10, 2022, 07:05 |
Rep Power: 4 |
Hello everyone,
I have a simulation of a building and I try to use cuttingPlane trought the building. Since the plane has 1974 faces, I was expecting to get the same amound samples but I got around 4000. Is there any way to limit the number of points to 1974? Here's my surfaces file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ surfaces { type surfaces; libs ("libsampling.so"); writeControl writeTime; surfaceFormat raw; fields ( U k epsilon); interpolationScheme cellPoint; surfaces ( zNormal { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (320 0 0); normal (1 0 0); } interpolate false; } ); } // ************************************************************************* // |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
