How to display lagrangian particles on a slice? |
August 21, 2022, 15:52 |
Huan Zhang
Rep Power: 5 |
Dear all,
I have particles in a 3d column, but I want to display the particles at a slice (e.g., center-plane), how can I do it in ParaView? Any suggestions? Thanks! Jasper |
August 21, 2022, 21:52 |
Huan Zhang
Rep Power: 5 |
Is there any suggestions? Very appreciate!
September 7, 2022, 05:53 |
Rep Power: 5 |
Hello
I am also looking for solutions to get 2-D packing at severals planes in 3D packing. here is my post: Plotting small particle fraction profiles along depth in 3D packing as you see i tried with clip filter but it doesnt produce 2-d planes cutting packing across specified plane. May be in your case it is useful. Let me know if you find another solution to visualize it. Best Regards Atul Jaiswal |
September 8, 2022, 02:54 |
Josh Williams
Rep Power: 5 |
To do this in paraview, you would need to create a small box maybe around 1-2% of the axis length (using `clip' tool), because if you take a slice, very few particles will be exactly on the slice. Then you can use `glyph' to visualise them. Alternatively, I have used Python for this Code:
from glob import glob import vedo as v import matplotlib.pyplot as plt import numpy as np def get_slices(pos, axis_to_slice=2, z_coord=3.0, thickness_pct=1): """ pos (np.ndarray) : particle positions axis_to_slice (int, 0,1 or 2) : which axis to be normal to cross section z_coord (float) : z-location to take slice at thickness_pct (float) : thickness of slice to take cross section at """ cut_larger_than_slice = pos[:, 2]>z_coord*(1+thickness_pct/100) cut_less_than_slice = pos[:, 2]<z_coord*(1-thickness_pct/100) del_inds = np.where(cut_less_than_slice | cut_larger_than_slice) pos = np.delete(pos, del_inds, axis=0) return pos # find and read VTK object fname = glob("VTK/lagrangian/kinematicCloud/kinematicCloud_*.vtk") assert len(fname) >=1, "no vtk files found" particles = v.load(fname[0]) marker_size = 2 z_coord = 1 # location that you want to take cross section at pos = particles.points() pos = get_slices(pos, z_coord=z_coord) del particles print("particles in slice", pos.shape[0]) xsize = 8.0 / 2.54 fig, ax = plt.subplots(1,1, figsize=(xsize, xsize)) ax.scatter(pos[:, 0], pos[:, 1], s=marker_size, c="black", marker='o', facecolors='black',) ax.axis('off') ax.autoscale_view('tight') # fig.tight_layout() plt.show() # plt.savefig('image.png', bbox_inches='tight',pad_inches = 0, dpi=400) |
September 8, 2022, 05:40 |
Rep Power: 5 |
Hi Josh
It would be great if you cpuld share your .VTK file on which I can test the python code. I am not familiar with python and it difficlut to follow without example. I have sent you my private email address via private message here. Best Regards Atul |
September 8, 2022, 05:56 |
Josh Williams
Rep Power: 5 |
Hi Atul,
You can generate data for this by running the MPPICFoam tutorial "injectionChannel" (available in OpenFOAM 6). To generate VTK file for LIGGGHTS, you can use LPP (link). If you are not familiar with python, maybe easier to go with the "box" clipping approach I mentioned in Paraview. |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 07:21 |
Radiation heating of lagrangian particles in reactingParcelFoam | CHUIKOV | OpenFOAM Running, Solving & CFD | 0 | February 28, 2021 14:53 |
Corellation dimension of lagrangian particles | oswald | OpenFOAM Post-Processing | 0 | January 27, 2016 07:30 |
Add lagrangian particles to OpenFoam solver | luchen2408 | OpenFOAM | 0 | June 2, 2015 03:10 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 07:43 |
