Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
NACA 2412 - high drag values, error reconstructPar
Old   October 25, 2022, 18:03
Post Airfoil error with finer refinement
Max
max_307 is on a distinguished road
with 5.600.000 Cells, I'm getting good results for my NACA 2412 validation. If I'm going for more cells with a finer refinement box, the simulation crashes. I use simpleFoam with a Reynolds Number of 3,1*10^6 (v=73.7 m/s) for validation. The wing has infinite wing span (chord: 3ft, span:2ft). To check, if a can get a mesh independent solution, i need a mesh with more cells.
SnappyHexMesh runs without any errors and creates 15.000.000 cells in my case.
Then the errors begin with patchsummary.log. The relevant logs are in attatched. Everything works fine, when i set the refinement box under a value of 3.
Can someone tell me, why this happens?
Iam grateful for every answer.
max_307 is offline   Reply With Quote
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 06:04
High drag coefficient Cd values czhongrong OpenFOAM Post-Processing 0 December 5, 2015 22:49
Lift and Drag Coefficient data for NACA 2412 Airfoil mahbub03 Main CFD Forum 22 May 25, 2014 15:39
Symmetric NACA Airfoil Lift and Drag Data jrider22 Main CFD Forum 3 April 15, 2010 04:59
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
