Bug: Incorrect wallShearStress postProcess with MRF |
November 14, 2022, 04:25 |
M. Montero
Rep Power: 17 |
Hi all,
I have detected the same bug in OpenFOAMv1812 and v2106. When the simulation is running using simpleFoam, the samples generated are correct and the wallShearStress is correct over the turbine. When I use simpleFoam -parallel -postProcess -latestTime, the wallShearStress generated is incorrect because it does not take into account the MRF ( that the turbine is rotating). Does anyone knows how to solve it using the functionObject? Best Regards |
postProcess Utility: icoFoam -noFunctionObjects Why?How? | TeresaT | OpenFOAM Post-Processing | 8 | July 26, 2023 02:41 |
simpleFoam: Influence of MRF region dimensions on simulation results | Krao | OpenFOAM Running, Solving & CFD | 4 | March 29, 2022 21:33 |
[mesh manipulation] MRF zone enclosed in another MRF zone | Dikkeunit | OpenFOAM Meshing & Mesh Conversion | 0 | November 25, 2021 14:08 |
Error computing wallShearStress with simpleFoam | sita | OpenFOAM Post-Processing | 6 | November 4, 2018 15:02 |
why does 'sample' do this? wallShearStress question | CHARLES | OpenFOAM Post-Processing | 0 | August 7, 2013 19:30 |
