Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how to extract clipped cutting plane from flow solution
Old   December 12, 2022, 11:01
Default how to extract clipped cutting plane from flow solution
Giles Richardson
ufocfd is on a distinguished road
Im using the sampling plane feature to extract a cut plane from flow solution with postProcess -func sampling-plane, and this generates a vtk file of the cutplane which works fine.
But, I want to be able to clip or bound the cutting plane to make it smaller.
Is there any way to do this within the postProcess utility, or with toposet?
ufocfd is offline   Reply With Quote
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 05:21
[swak4Foam] error when use swak4foam to calculate the mass flow rate of a cutting plane ozs OpenFOAM Community Contributions 0 September 4, 2017 22:52
Very strange/incorrect flow solution all of a sudden. bndrylyr FLUENT 0 March 21, 2017 15:44
initialize flow field with steady state solution holg FLUENT 0 July 13, 2009 17:10
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
