Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
postProcess -func wallHeatFlux in openFoam 6
Like Tree5Likes
  • 1 Post By vs1
  • 2 Post By wyldckat
  • 1 Post By vs1
  • 1 Post By wyldckat
Old   August 22, 2018, 06:05
Default postProcess -func wallHeatFlux in openFoam 6
vs1
vaibhav
vs1 is on a distinguished road
Hi All,
Any idea why i am getting the below error on using this "postProcess -func wallHeatFlux" utlity for buoyantBoussinesqSimpleFoam solver ?
" Unable to find compressible turbulence model in the database "
Create time
Create mesh for time = 0
wallHeatFlux wallHeatFlux:
    processing all wall patches
Time = 0
Reading fields:
Executing functionObjects
--> FOAM FATAL ERROR:
    From function virtual bool Foam::functionObjects::wallHeatFlux::execute()
    in file wallHeatFlux/wallHeatFlux.C at line 240.
FOAM exiting
Thanks,
Vaibhav
mgsreenath likes this.
vs1 is offline   Reply With Quote
Old   August 22, 2018, 14:19
Retired Super Moderator
Bruno Santos
Quick answer: Unfortunately it's not possible at the moment. You will have to use this utility instead: https://github.com/wyldckat/wallHeatFluxIncompressible
Old   August 23, 2018, 08:52
vs1
vaibhav
Thanks for your reply.
Does this utility calculate convective heat transfer only or radiative as well ?
Regards,
Vaibhav
Old   August 23, 2018, 09:28
Bruno Santos
Quick answer: Convective only.
Old   June 4, 2023, 21:50
mactone hsieh
mactone is on a distinguished road
Have you tried
buoyantBoussinesqSimpleFoam -postProcess -func wallHeatFlux?
mactone is offline   Reply With Quote
postprocessing, wallheatflux
postProcess functionality in openFOAM 4 and total(p) LVDH OpenFOAM Post-Processing 3 August 9, 2017 09:11
postProcess functionality in openFOAM 4 bullmut OpenFOAM Post-Processing 23 July 21, 2017 09:11
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 04:57
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 09:33
