It would be wonderful if a tool for FoamToTecplot is available |
April 11, 2012, 21:09 |
#161 |
张德胜
Rep Power: 14 |
终于找到了同胞,我请教一个关于转化tecplot的问题,我现在使用OF2.1.0做了一个计算,我想将 结果在tecplot里面做后处理,但是OF2.1.0貌似不支持了。给点建议。我才接触这个转化,所以还 有很多不明白的地方。先谢了!
April 12, 2012, 03:09 |
#162 |
xinguang cui
Rep Power: 17 |
you can install another version of OpenFOAM, and transfer the data using the the that version. In fact, until now, I didn't update OpenFOAM version. You also can check the QQ from internet, there is OpenFOAM qq group. I am sure you can get more information from there.
good luck |
April 12, 2012, 03:48 |
#163 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Based on flying's answer, I suppose the issue was a problem with foamToTecplot360 not being available with the latest versions of OpenFOAM. For that, there are two answer's:
Bruno
April 13, 2012, 14:07 |
#164 |
Scott Rumage
Rep Power: 17 |
Hello All,
Tecplot currently offers support for the OpenFOAM data loader that comes with Tecplot 360. We are not currently supporting the foamToTecplot360 data converter. Regards, Scott |
May 14, 2012, 21:40 |
#165 |
Ehsan
Rep Power: 17 |
Hello all,
I tried to export a 3D solution from OpenFOAM into the tecplot but I got "memory allocation failure" error. How could I increase the size of default memory so that I see my solution? Regards |
November 27, 2012, 06:54 |
parallel for tecplot
#166 |
ya
Rep Power: 15 |
I have same problem, I try to use foamToTecplot360 -parallel to separate my case into several tecplot block, but it is not work, dose anybody have some idea?
Problem manipulating Data in Tecplot after foamToTecplot Conversion | titio | OpenFOAM Post-Processing | 2 | June 10, 2010 04:23 |
CFD science or tool? | Mateusz | Main CFD Forum | 10 | November 24, 2008 23:16 |
[mesh manipulation] ScalePoints tool | cedric_duprat | OpenFOAM Meshing & Mesh Conversion | 6 | September 19, 2008 03:15 |
Gridgeneration Tool | AndyR | Main CFD Forum | 2 | May 23, 2008 08:49 |
PDF repaire tool? | John | Main CFD Forum | 0 | February 23, 2008 07:32 |
