Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problems with reconstructParMesh and reconstructPar in 15
Like Tree6Likes
Old   January 15, 2009, 09:01
Default Dear all, I have a problem
Edin Berberovic
eberberovic is on a distinguished road
Dear all,
I have a problem in reconstructing a decomposed case of interDyMFoam solver. I calculated the tutorial case damBreakWithObstacle using 4 processors on a 64-bit machine. When doing reconstructParMesh, the mesh seems to be reconstructed, but I always get the following warning, e.g. for reconstructParMesh -time 0.02:
--> FOAM Warning :
From function boundBox::boundBox(const pointField& points)
in file meshes/boundBox/boundBox.C at line 52
Cannot find bounding box for zero sized pointField, returning zero
Since the mesh seems to be reconstructed, I wonder what this warning is about?
The real problem starts afterwards. When I issue e.g. reconstructPar -time 0.02, I get the following:
Create time
Create mesh for time = 0.02
Time = 0.02
#0 Foam::error::printStack(Foam:stream&) in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::objectRegistry::checkOut(Foam::regIOobject&) const in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::regIOobject::checkOut() in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::regIOobject::~regIOobject() in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::IOList<int>::~IOList() in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/applications/bin/linux64GccDPOpt/rec onstructPar"
#7 Foam::processorMeshes::read() in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/applications/bin/linux64GccDPOpt/rec onstructPar"
#8 Foam::processorMeshes::readUpdate() in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/applications/bin/linux64GccDPOpt/rec onstructPar"
#9 main in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/applications/bin/linux64GccDPOpt/rec onstructPar"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 Foam::regIOobject::readIfModified() in "/home/eberberovic/OpenFOAM/OpenFOAM-1.5_64/applications/bin/linux64GccDPOpt/rec onstructPar"
./reconstruct: line 4: 19180 Segmentation fault reconstructPar -time 0.02
So I am not able to do the reconstruction of the case. I am asking for help as a not really experienced user. Does anyone know why this happens?
Thanks a lot in advance.
eberberovic is offline   Reply With Quote
Old   January 15, 2009, 11:54
Default Hi I use a lot reconstructP
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
floooo is on a distinguished road
Hi
I use a lot reconstructParMesh, but I've never seen this error.
I know that there is a option call 'nozero' and which is not documented.
Usage: reconstructParMesh [-noZero] [-region region name] [-fullMatch] [-mergeTol relative merge distance] [-case dir] [-constant] [-latestTime] [-time time] [-help] [-doc] [-srcDoc]
I have no idea of the usage of this option, but try it. There is may be a relation with your error message which talk about 'bounding box for zero'
Florian
floooo is offline   Reply With Quote
Old   January 15, 2009, 14:25
Default The zero 'bounding box' comes
Mattijs Janssens
mattijs is on a distinguished road
The zero 'bounding box' comes from the algorithm which starts with an empty mesh and adds all the other ones into it. 'noZero' is just a time option.
Do you see the problem in 1.5.x? If so could you put a bug report + testcase on OpenFOAM-bugs?
mattijs is offline   Reply With Quote
Old   January 16, 2009, 08:44
Default Mattijs, thanks a lot for t
Edin Berberovic
Mattijs,
thanks a lot for the response. Unfortunately at the moment I am still not able to update patches from 1.5.x. using git. When there are some changes, I copy them into my 1.5 version and compile manually. I hope that I will be provided with this possibility soon.
But I have found out something else, which might be a clue for you where this "bug" might reside. When I perform the reconstruction from outside the case directory, then I do not get any error messages while reconstructing the fields. For example reconstructParMesh &ndash; case damBreakWithObstacle -time xxx and afterwards reconstructParMesh &ndash; case damBreakWithObstacle -time xxx works fine. I use a small script with these lines for every time step and everything seems to work, only the warning from reconstructing the mesh still persists. But as I understood this is ok?
Reconstruction from inside the case directory always gives me the problem with printStack... in certain (not all) time directories.
Since I do not know if this is a bug, I am posting the case here (same as in the release, only the starting mesh is finer and the criterion for refining/unrefining is a bit different). If I find the same problem in 1.5.x, then I will report a bug.
Best Regards.
Old   January 16, 2009, 08:47
Default Here is the case: http://w
Edin Berberovic
Here is the case:
damBreakWithObstacle.tgz
Old   April 30, 2009, 07:38
Francesco Contino
francesco is on a distinguished road
I have a similar problem running an application derived from dieselEngineFoam and using engineTopoChanger.
When using reconstructParMesh, I have the following error:
Create time
This is an experimental tool which tries to merge individual processor
meshes back into one master mesh. Use it if the original master mesh has
been deleted or if the processor meshes have been modified (topology change).
This tool will write the resulting mesh to a new time step and construct
xxxxProcAddressing files in the processor meshes so reconstructPar can be
used to regenerate the fields on the master mesh.
Not well tested & use at your own risk!
Merge tolerance : 1e-07
Write tolerance : 1e-08
Doing geometric matching on correct procBoundaries only.
This assumes a correct decomposition.
Found 2 processor directories
Reading database "Hessel/processor0"
Reading database "Hessel/processor1"
Setting master time to -175
Reading points from "Hessel/processor0" for time = -175
Reading points from "Hessel/processor1" for time = -175
Overall mesh bounding box : (0 -0.01 0.00011442647) (0.1 0.01 0.1)
Relative tolerance : 1e-07
Absolute matching distance : 1.4274848e-08
Constructing empty mesh to add to.
--> FOAM Warning :
Reading mesh to add from "Hessel/processor0" for time = -175
Adding to master mesh
Segmentation fault
I am not sure where this comes from. My case is axisymmetric does that have any influence?
Thank you for your help.
Francesco
francesco is offline   Reply With Quote
Old   April 30, 2009, 07:54
Francesco Contino
Does the use of engineTopoChanger have an impact on reconstructParMesh?
Francesco.
Old   May 3, 2009, 05:28
Francesco Contino
If the reconstructParMesh doesn't work, is it possible to force writing the ***ProcAdressing during solving time?
Where can I find the files responsible for that part?
Francesco.
Old   May 3, 2009, 10:58
Francesco Contino
Here is the case directory where the application is not working:
HesselProb.tar.gz
And the quite simple application derived from dieselEngineFoam and named dieselEngineFoamLayer:
dieselEngineFoamLayer.tar.gz
I hope that anybody will be able to help me.
Francesco.
Old   May 4, 2009, 04:49
Francesco Contino
As I have the same problem with engineFoam, I've analyzed the mesh instead.
It seems that the use of a axisymetric mesh does not work.
I will post a message in the bug section.
Old   March 8, 2010, 12:32
Wolfgang W.
WiWo is on a distinguished road
Hello everyone,
I don't know if this thread is still active but I'm posting here because my problem resembles exactly the one Edin is reporting - just in OF-1.6.
I've been running the dambreakWithObstacle case on 6 processors in parallel to test the performance - everything fine so far. But the reconstruction of the result proved to be troublesome.
I can run "reconstructParMesh -mergeTol 1e-06 -time xxx" for every timestep from the case directory or from outside (like Edin explained). But I can not - neither from within the case directory nor from outside - run the reconstructPar utility for a time different than 0. I'm always ending up with the following error:
[cluster damBreakWithObstacleSave]$ reconstructPar
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-f802ff2d6c5a
Exec : reconstructPar
Date : Mar 08 2010
Time : 18:26:29
Host : brutus2.ethz.ch
PID : 4879
Case : /cluster/home/mavt/wwiedema/OpenFOAM/wolfgang-1.6/tutorials/damBreakWithObstacleSave
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0.041
Time = 0.001
Reconstructing FV fields
Reconstructing volScalarFields
alpha1
p
alpha1.org
Reconstructing volVectorFields
U
No point fields
No lagrangian fields
Time = 0.021
#0 Foam::error:rintStack(Foam::Ostream&) in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam:bjectRegistry::checkOut(Foam::regIOobject&) const in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::regIOobject::~regIOobject() in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::IOList<int>::~IOList() in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/reconstructPar"
#6 Foam:rocessorMeshes::read() in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/reconstructPar"
#7 Foam:rocessorMeshes::readUpdate() in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/reconstructPar"
#8 main in "/cluster/home/mavt/wwiedema/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/reconstructPar"
#9 __libc_start_main in "/lib64/libc.so.6"
#10 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Segmentation fault
The odd thing is that there is always a folder 0.001 beeing created which does not contain a polyMesh directory before he screws up.
Does anybody have an idea what is going wrong here - or more likely what I'm doing wrong?
I would appreciate any advice or hint on this issue.
Cheers,
Wolfgang
WiWo is offline   Reply With Quote
Old   March 9, 2010, 16:17
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hi Wolfgang.
Did you use a dynamic mesh?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   March 10, 2010, 11:06
Wolfgang W.
Hi Sebastian,
Yes, I used the damBreakWithObstacle tutorial case included in OF-1.6 which employs 'dynamicFvMesh dynamicRefineFvMesh'.
Everything works fine with the case - so decomposition into subdomains and parallel solving. Just when attempting to reconstruct the solution from the information in the subdomains things become tricky.
Best regards,
Wolfgang
Old   March 10, 2010, 11:24
sega's Avatar
Sebastian Gatzka
Originally Posted by WiWo View Post
Hi Sebastian,
Best regards,
Wolfgang
Yes. You have to apply the reconstructParMesh and reconstructPar alternating for each time step!
I have a small script for that.
#!/bin/bash
timeList=$(ls processor0/ | awk '$1!="constant"');
for line in $timeList
do
    echo "Recontructing mesh for t = "$line" s";
    reconstructParMesh -time $line > logTmp;
    echo "Reconstructing fields for t = "$line" s";
    reconstructPar -time $line > logTmp;
    echo "";
done
rm logTmp;
Try it!
Old   March 18, 2010, 11:29
Wolfgang W.
Hi Sega,
That was the clue - thank's a lot! I didn't think of running it time step by time step in an alternating fashion.
Your script works also great :-)
Cheers,
Wolfgang
Old   June 15, 2010, 11:27
Robert Castilla
rcastilla is on a distinguished road
Sebastian,
that was exactly wath I was looking for! Thanks a lot.
Robert
rcastilla is offline   Reply With Quote
Old   April 15, 2012, 06:25
Hrushikesh Khadamkar
Hrushi is on a distinguished road
#!/bin/bash
do
    echo "";
done
rm logTmp;
Try it!
Hi Sebastian,
I ran the above script. It reconstructs the mesh but while reconstructing the fields it gives error. I am posting the output result of the script.
Recontructing mesh for t = 0 s
--> FOAM FATAL ERROR:
Your time was specified as 0 but there is no polyMesh/points in that time.
(there is a points file in "constant")
Please rerun with the correct time specified (through the -constant, -time or -latestTime (at your option).
From function reconstructParMesh
in file reconstructParMesh.C at line 449.
FOAM exiting
Reconstructing fields for t = 0 s
No times selected
in file reconstructPar.C at line 139.
FOAM exiting
Recontructing mesh for t = 0.005 s
Reconstructing fields for t = 0.005 s
#0 Foam::error:rintStack(Foam::Ostream&) in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#3 Foam:bjectRegistry::checkOut(Foam::regIOobject&) const in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#4 Foam::regIOobject::~regIOobject() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libOpenFOAM.so"
#5 Foam::IOList<int>::~IOList() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libfiniteVolume.so"
#6 Foam:rocessorMeshes::read() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libreconstruct.so"
#7 Foam:rocessorMeshes::readUpdate() in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/lib/libreconstruct.so"
#8 main in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/reconstructPar"
#10 _start in "/Storage1/cfd/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64Gcc45DPOpt/bin/reconstructPar"
./recd: line 4: 5337 Segmentation fault (core dumped) reconstructPar -time $line >logTmp
Recontructing mesh for t = 0.01 s
After running the script, I have polyMesh directory in all time dumps in my case directory. But there are no fields.
What can be the reason for this?
Hrushikesh
Hrushi is offline   Reply With Quote
Old   June 5, 2012, 10:59
idefix is on a distinguished road
I´ve got the same problem
I used interDyMFoam and 104 CPUs
but unfortunately reconstructPar didn´t work. After I realised that it doesn´t work I tried that way:
reconstructParMesh -constant --> worked well
reconstructPar -constant --> didn´t work.
Here´s the mistake I got:
Create time
Create mesh for time = 1.4e-05
Time = constant
#0 Foam::error::PrintStack(Foam::Ostream&) in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
#3 Foam:: objectRegistry::checkOut(Foam::regIOobject&) const in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::regIOobject::~regIOobject() in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam::IOList<int>::~IOList() in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6 Foam:: processorMeshes::read() in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libreconstruct.so"
#7 Foam:: processorMeshes::readUpdate() in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libreconstruct.so"
in "/home/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/reconstructPar"
at /usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:116
Speicherzugriffsfehler
Has anyone an idea what´s wrong?
Thanks a lot
idefix is offline   Reply With Quote
Old   August 22, 2012, 11:40
Default Same problem here.
  #19
Suro Kim
imsurokim is on a distinguished road
I tried your script, and still have the problem..
I don't know what is wrong, but few people have same problem like me.
I am running 2.1.1
Any suggestions?
Create time
Time = 0.02
#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#3 Foam:bjectRegistry::checkOut(Foam::regIOobject&) const in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#4 Foam::regIOobject::~regIOobject() in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#5 Foam::IOList<int>::~IOList() in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libfiniteVolume.so"
#6 Foam:rocessorMeshes::read() in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libreconstruct.so"
#7 Foam:rocessorMeshes::readUpdate() in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libreconstruct.so"
#8 main in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/bin/reconstructPar"
#10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/usr/local/OpenFOAM-2.1.1/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/bin/reconstructPar"
imsurokim is offline   Reply With Quote
Old   August 22, 2012, 16:44
Retired Super Moderator
Bruno Santos
Greetings Suro Kim and welcome to the forum.
What does this command output:
If it outputs this message:
Your current settings specify ASCII writing with 6 digits precision.
Your merging tolerance (1e-07) is finer than this.
Please change your writeFormat to binary or increase the writePrecision
or adjust the merge tolerance (-mergeTol).
    in file reconstructParMesh.C at line 341.
FOAM exiting
Then it's because you need to change the following line in "system/controlDict" from:
writeFormat     ascii;
to:
writeFormat     binary;
Then run again:
If there is no error message, then you should be able to safely run sega's script.
Best regards,
Bruno
smraniaki likes this.
Bug in reconstructPar david OpenFOAM Bugs 10 May 26, 2009 12:11
ReconstructPar kupiainen OpenFOAM Post-Processing 12 April 21, 2009 01:47
[mesh manipulation] Error with reconstructPar skabilan OpenFOAM Meshing & Mesh Conversion 3 June 10, 2008 18:34
ReconstructPar maka OpenFOAM Bugs 6 August 22, 2007 04:23
Problem with reconstructPar fabianpk OpenFOAM 5 August 14, 2007 09:17
