Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problem with sample utility
Old   August 23, 2007, 11:53
Default hi me again. i read about the
robert maduta
roberthino is on a distinguished road
hi me again. i read about the sample utility and decided that it is a much cleaner way to plot graphs than probe. my problem is that after i finished a calculation with FoamX and i puch the execute button for sample (configuration: uniform, along a line) it is initializing the mesh and writing something for every iterationstep, but than if i take a look in the dictionary on my hd (sample) and if i go to any iterationstep, there is absolutely no data written there? someone can help?
roberthino is offline   Reply With Quote
Old   August 23, 2007, 13:16
Default All data extracted using the s
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
All data extracted using the sample utility gets written to a new directory called samples inside your case.
msrinath80 is offline   Reply With Quote
Old   August 23, 2007, 13:21
Default jup thats what i thought....in
robert maduta
jup thats what i thought....in that samples directory there are all the iterations steps in new directories. but these directories are empty there is no data
Old   August 23, 2007, 13:25
Default That's odd. Do one thing. Use
That's odd. Do one thing. Use the default caviy case with icoFoam and extract the velocities along a line through the center of the cavity. See if that works first.
Old   August 23, 2007, 14:39
Default Hallo Robert, 1. Which vers
Jens Klostermann
jens_klostermann is on a distinguished road
Hallo Robert,
1. Which version of OF do you use? I had also some problems with sampling in OF-1.3? Try to change the interpolation in the sampleDict.
2. Make sure your sample line (coordinates of first and last point) is within your domain!
Jens
jens_klostermann is offline   Reply With Quote
Old   August 23, 2007, 15:14
Default thx a lot, i use version 1.4..
robert maduta
thx a lot, i use version 1.4......well my first and last point are exactly on my left and right boundary. is that allowed? anyway i am going to try it tomorrow at the pc at work. what do you mean by changing the interpolation? i used uniform and 100 points in between
Old   August 23, 2007, 15:29
Default I faced the same problem a whi
I faced the same problem a while ago[1]. The suggestion was to move to the cloud option as opposed to the line option. Check the thread below for more information.
[1] http://www.cfd-online.com/OpenFOAM_D...es/1/3611.html
Sample utility problems msrinath80 OpenFOAM Running, Solving & CFD 12 December 21, 2012 05:51
OF15x sample utility does not accept component elisabet OpenFOAM Bugs 2 February 18, 2009 11:58
Sample utility problem in OpenFOAM141dev 7islands OpenFOAM Bugs 1 January 4, 2008 08:34
About the problem of decomposePar utility zou_mo OpenFOAM Running, Solving & CFD 3 July 27, 2005 18:18
SOLAVOF Sample Test Problem Zi-Wei Chiou Main CFD Forum 0 October 27, 2001 00:35
