Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Velocity Components in foamDataToFluent
Old   January 26, 2009, 09:15
Default Hi all. I'm trying to export
Flavio Pergolesi
flavio_pergolesi is on a distinguished road
Hi all.
I'm trying to export some results from foam to fluent.
I realized that something strange happens, because when I plot the velocity magnitude (in contour or vectors) fluent displays something similar to paraFoam, but if I plot velocity components it displays a 0 value field, or strange results that don't even fit with the direction of the flow.
As I found in a thread concerning this topic, I specified in foamToFluentDictionary not only the vector field U on entry number 2 but also the components Ux (entry 111), Uy (112), Uz (113).
But I still can't import the data correctly in Fluent.
Thanks in advance for any help you might feel like to give.
Flavio
flavio_pergolesi is offline   Reply With Quote
Old   November 9, 2009, 09:27
Smile Hello
shuminhua
shuminhua is on a distinguished road
I want to postprocess the openFOAM results in Fluent .When I use foamDataToFluent to change it , it generate *.dat files ,but I need *.dat and *.cas in fluent. What i should to do?
Thanks for all reply!
shuminhua is offline   Reply With Quote
velocity components at blade tip Sridevi CFX 3 April 30, 2022 11:55
What are the UVW velocity components Nikunj FLUENT 2 January 12, 2022 12:28
Obtaining velocity components srinath OpenFOAM Programming & Development 16 March 27, 2021 12:49
How to specify velocity components in UDF Ynot FLUENT 1 March 11, 2006 13:53
Velocity components visualization Sileno Phoenics 1 September 28, 2005 12:06
