Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculation of mass flow rate through a plane
Old   July 2, 2010, 14:00
Default Calculation of mass flow rate through a plane
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Dear Foamers,
Is there any way of calculating the mass flow rate through a given plane of the mesh that is not a patch boundary. I found in the forum the calcMassFlow utility, but I have some doubts if I can use for a non patch plane.
My idea was to use the simpleFunctionObjects in the controlDict file, but I do not understand what function should I use.
Also, is it possible to calculate two values of flow rate and then calculate the value of a parameter, all defined in the controlDict file? I believe this is better done in the code, right?
Anyone can help me out here?
António Martins
titio is offline   Reply With Quote
Old   September 27, 2010, 16:55
Robin Gilbert
robingilbert is on a distinguished road
Hi titio,
Did you figure out how to calculate the mass flow-rate through a non patch plane?
robingilbert is offline   Reply With Quote
Old   September 28, 2010, 00:28
Robin Gilbert
I just now figured it out. if anybody is interested, they can use swak4Foam by
Bernhard Gschaider. here is the link:
it has a tutorial for angled duct which shows how it is done.
http://openfoamwiki.net/index.php/Contrib/swak4Foam
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
The reporting of mass flow rate summer FLUENT 1 July 12, 2007 09:35
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
