Catia To OpenFoam
Old   October 2, 2012, 13:35
Default Catia To OpenFoam
hadi abdollahzadeh
dark lancer is on a distinguished road
hi
I have some file(.stl) and I want to input to the openfoam but I can't?
I want use dsmc code for solve the my problem but I dont know where I can an example that use of dsmc.
for any help I well appriciate
dark lancer is offline   Reply With Quote
Old   October 2, 2012, 16:30
Retired Super Moderator
Bruno Santos
Greetings Dark lancer,
Those are somewhat two different topics, because:
  1. The STL is probably the geometry for which you want to create a mesh. In OpenFOAM, the usual way to generate a mesh with STL as the geometry, is to use snappyHexMesh: http://openfoamwiki.net/index.php/SnappyHexMesh
  2. For DSMC, check the tutorials available in "discreteMethods/dsmcFoam".
If you are still unfamiliar with how OpenFOAM works and where the tutorials are, then read the OpenFOAM User Guide: http://www.openfoam.org/docs/user/
Best regards,
Bruno
Old   October 4, 2012, 07:16
hadi abdollahzadeh
thanks wyldckat
ok
I am reading user guide but I found an Instructions and I follow them
after I save my file with(.stl) I use NETGEN softwar for generating mesh and save with (.vol) and now I don't know what I do with these files?
Old   October 5, 2012, 08:04
Elvis
elvis will become famous soon enough
so you want to take the netgenNeutralToFoam way http://openfoamwiki.net/index.php/NetgenNeutralToFoam (remark:foamX does not exist any more [used to be a Java GUI with few capabilaties])
in this forum =>http://www.cfd-online.com/Forums/ope...-openfoam.html
But Bruno is correct from STL it is a good way to use SnappyHexMesh(SHM) and I would use Helyx OS as a GUI to tackle SHM.
elvis is offline   Reply With Quote
Issues with OpenFoam sanjibdsharma OpenFOAM 0 August 14, 2009 08:41
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
2009 OpenFOAM Summer School in Zagreb, Croatia hjasak OpenFOAM Announcements from Other Sources 0 March 27, 2009 12:08
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
