block with a hole
Old   April 17, 2013, 01:22
Default block with a hole
Vishal Nandigana
nandiganavishal is on a distinguished road
Hello Foamers,
I would like to create the following geometry in openfoam.
A small circular hole is drilled through a block (cuboid in shape). Please let me know how to create such a geometry in openfoam.
Thanks
Vishal
nandiganavishal is offline   Reply With Quote
Old   April 17, 2013, 03:28
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
There is an example of how to do this in the user guide. You just have to extend it from 1/4 to the full block. Shouldn't bee difficult.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   April 18, 2013, 01:37
Vishal Nandigana
Thanks, Anton for the reply. Yes, this geometry is doable. What I wanted to create is the following geometry that is attached with this thread. A cylindrical hole is drilled through three membranes (two thick membranes and a thin membrane in the center). The membrane is then connected to two reservoirs on either side. I would like to know if there is a general code or format to create any geometry without having to define the vertices manually. Please let me know !!
Thanks
Regards,
Vishal
Old   April 18, 2013, 17:18
Retired Super Moderator
Bruno Santos
Greetings to all!
@Vishal: Try SwiftBlock: http://openfoamwiki.net/index.php/Contrib/SwiftBlock - this way you can create a "blockMeshDict" interactively.
Best regards,
Bruno
Old   April 29, 2013, 12:20
Vishal Nandigana
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thanks, Bruno. I would take a look at it.
Regards,
Vishal
[blockMesh] FOAM FATAL ERROR: Inconsistent number of faces blockMesh::createMergeList() line 193 Hengel OpenFOAM Meshing & Mesh Conversion 7 November 15, 2021 22:56
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 10:01
[ICEM] Quest for seemingly simple Blocking (degenerate block) la7low ANSYS Meshing & Geometry 0 July 12, 2011 19:48
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
