Odd behavior on the outlet
Old   December 29, 2015, 06:39
Question Odd behavior on the outlet
a_habib's Avatar
Ahmad Habib
a_habib is on a distinguished road
Hello Everyone.
I don't know if this is the correct place for my thread.
I'm trying to simulate the flow in an air supply system (using incompressible S-A DDES) as you can see in the attached photo and I'm interested only in the flow in the duct's end region, but I'm noticing an odd behavior, the semi-spherical surface should be an outlet but the flow is not completely exiting throw the outlet, and I think that could effect the solution quality.
My BC at the outlet:
For U:
    outlet
        type            inletOutlet;
        value           $internalField;
        inletValue      $internalField;
and for p:
    outlet
	type            outletInlet;
	outletValue	uniform 0;
	value		uniform 0;
Any one can explane the reason of this behavior
If this is wrong ... what I should use?
Or I should use different outlet shape for my simulation?
Thanks in advance.
File Type: jpg Screenshot from 2015-12-29 13:15:23.jpg (75.9 KB, 12 views)
a_habib is offline   Reply With Quote
Old   January 7, 2016, 14:04
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
set totalPressure for pressure field, zeroGradient for U
mkraposhin is offline   Reply With Quote
outlet, outlet boundary condition
species - pressure outlet cfd user FLUENT 7 March 13, 2012 23:36
Outlet BC for disturbed Poiseuille flow murx CFX 10 February 22, 2012 13:55
Pressure outlet boundary condition fluent_newbie FLUENT 0 December 1, 2011 23:51
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? david39 OpenFOAM Running, Solving & CFD 6 February 2, 2011 03:01
outlet boundary condition neil CFX 1 June 17, 2002 00:57
