Allinging an stl file in background mesh
Old   July 3, 2015, 01:28
Default Allinging an stl file in background mesh
kcn
kcn is on a distinguished road
I'm trying to simulate a wind turbine in OpenFOAM. The impeller geometry is available as a stl file and I'm using snappyHexMesh with a background mesh to do the meshing.
I need to specify the axis of rotation in dynamicMeshDict. This should pass through the center of turbine blade.
My problem is how can I obtain the coordinates of the center point of stl file (turbine blade) located in background mesh?
Can some one please help?
Thanks
kcn
kcn is offline   Reply With Quote
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
