using modified version of dambreak tutorial
Old   March 3, 2014, 14:36
Default using modified version of dambreak tutorial
Matt_h is on a distinguished road
Hi
I am trying to modify the damBreak tutorial mesh to create a virtual model of a fire sprinkler. I know someone has done this already but I want to change the viscosity of the water, and also add in my own sprinkler geometry. I'm trying to test out different variables such as the inlet diameter and angle at which the water impinges, and see the effect this has on how far the spray reaches across the room.
I've created a mesh however I am struggling with the boundary conditions, in particular "atmosphere". I assumed this simulates the air in the room but may be wrong?. I have a small section as the inlet which is where the water comes out of the sprinkler, and I am using the symmetry for other since it is a quarter of the model.
If anyone has any advice whatsoever that would be much appreciated! I am relatively new to OpenFOAM.
Thanks in advance
Matt_h is offline   Reply With Quote
dsmcFoam modified version download Marta OpenFOAM 27 July 1, 2023 10:23
[Other] Modification of multi region heater tutorial geometry mukut OpenFOAM Meshing & Mesh Conversion 2 October 4, 2013 20:59
Error, running a modified version of twoPhaseEulerFoam foamer OpenFOAM Running, Solving & CFD 0 March 11, 2012 16:17
CFD-ACE Tutorial for Serpentine Fuel cell Channel Taqi Main CFD Forum 0 April 13, 2008 13:12
Problem starting a tutorial case alank OpenFOAM Installation 1 December 12, 2006 16:50
