Problems to recreate mixerVesselAMI2D Tutorial with imported Mesh from Pointwise
Old   March 28, 2014, 10:17
Default Problems to recreate mixerVesselAMI2D Tutorial with imported Mesh from Pointwise
carsten fuetterer
carstenf is on a distinguished road
Hi folks,
actually I try to simulate a 2D VAWT, but I'm facing a problem. Thats why I used this geometry with different boundary conditions and imported it into the mixerVesselAMI2D tutorial. I renamed all boundaries so that they are the same as in the tutorial.
I guess that there is some problem with the AMI interface?
Here is the error message:
|  \\    /   O peration     | Version:  2.2.0                                 |
Build  : 2.2.0
Exec   : pimpleDyMFoam
Date   : Mar 28 2014
Time   : 15:18:57
Host   : "elmo"
PID    : 14936
Case   : /homes/saturn/users/fuetterer/work/VAWT/openfoam/mixer
nProcs : 1
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone rotor
Reading field p
Reading field U
AMI: Creating addressing and weights between 105 source faces and 105 target faces
AMI: Patch source weights min/max/average = 1, 1, 1
AMI: Patch target weights min/max/average = 1, 1, 1
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading field rAU if present
Creating finite volume options
Creating fintite volume options from fvOptions
Selecting finite volume options model type MRFSource
    Source: MRF1
    - applying source for all time
    - selecting cells using cellZone rotor
    - selected 19157 cell(s) with volume 3.95344
PIMPLE: Operating solver in PISO mode
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 0.00119048
Time = 0.00119048
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00119048 transformation: ((0 0 0) (0.999993 (0 0 0.00373998)))
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/opt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const in "/opt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "/opt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/pimpleDyMFoam"
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
Floating point exception
Here is the checkMesh. but everything seems ok
Build  : 2.2.0
Exec   : checkMesh
Date   : Mar 28 2014
Time   : 16:08:56
Host   : "elmo"
PID    : 15454
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            67415
    internal faces:   28370
    cells:            19157
    faces per cell:   5
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     0
    prisms:        19157
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    AMI2                105      210      ok (non-closed singly connected)
    AMI1                105      210      ok (non-closed singly connected)
    back                19157    9837     ok (non-closed singly connected)
    front               19157    9837     ok (non-closed singly connected)
    rotor               441      882      ok (non-closed singly connected)
    stator              80       160      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-3 -3 0.649439) (3 3 0.759439)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-1.80718e-19 3.07221e-18 -5.3269e-15) OK.
    Max cell openness = 2.24895e-16 OK.
    Max aspect ratio = 2.7008 OK.
    Minimum face area = 1.50277e-06. Maximum face area = 0.0448934.  Face area magnitudes OK.
    Min volume = 1.65305e-07. Max volume = 0.00493827.  Total volume = 3.95344.  Cell volumes OK.
    Mesh non-orthogonality Max: 30.7872 average: 8.36886
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.488016 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
can someone help me?
best regards
Carsten
carstenf is offline   Reply With Quote
Old   April 8, 2014, 17:25
carsten fuetterer
Ok, I got help from the Pointwise Service.
Before running the case following action has to be executed
renumberMesh -overwrite
Importing 2D separated Hybrid mesh from PointWise to Ansys Fluent Masoud.A1 Pointwise & Gridgen 6 July 8, 2017 09:23
[ICEM] PistonVale tutorial - issues about mesh quality Andrea1984 ANSYS Meshing & Geometry 5 October 11, 2013 09:30
[Gmsh] Scripted version of "2D Mesh Generation Tutorial for GMSH" laubeg OpenFOAM Meshing & Mesh Conversion 1 April 14, 2013 08:32
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
