March 31, 2014, 21:58 |
Solving After Mapping Fields
Sohail
Rep Power: 12 |
Hello All,
I am having a problem with mapFields. I want to map the solution from case 14 to case 1 I only have the "0" directory in case 1. I issue blockMesh for case 1, then I used the command "mapFields ../14/ -case ../1/ -sourceTime latestTime" and it works fine. In my "0" folder of case 1, i see the non-uniform internal field with sources. I then issue snappyHexMesh. Everything works file till here. However when I try to run the solver, it gives me the error, "size 2736000 is not equal to the given value of 2735450" Can anyone help me out with this?? Thanks, |
April 3, 2014, 14:29 |
MapFields from Fine Mesh to Coarse Mesh
Sohail
Rep Power: 12 |
Hello All,
I wanted to know if its possible to map solution from a fine mesh onto a coarser mesh. I tried using mapFields normally and it returned "size _ is not equal to the given value of _" Does anyone know how to do this? Thanks, |
April 6, 2014, 14:52 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
mapfields, mapfieldsdict, openfoam, size not equal |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
