April 18, 2014, 23:31 |
Running angledDuct with Helyx-OS
Tom
Rep Power: 12 |
I'm trying tu run the OpenFOAM case $FOAM_RUN/tutorials/compressible/rhoPimpleFoam/ras/angledDuct in Helyx-OS However I always get the same error: Courant Number mean: 17440.39376 max: 100962.1543 Time = 3 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 0.8219688794, Final residual = 0.03374783005, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.9154234759, Final residual = 0.01271857728, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 0.867933914, Final residual = 0.0008835231928, No Iterations 1000 smoothSolver: Solving for h, Initial residual = 0.9996656019, Final residual = 0.01280944088, No Iterations 1000 #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so" #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::sutherlandTransport<Foam:: species::thermo<Foam::hConstThermo<Foam:erfectGa s<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so" #5 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoPimpleFoam" /home/tom/Engys/RHOPIMPLE/solver.run: line 22: 8576 Floating point exception(core dumped) $SOLVER -case $CASE 2>&1 8577 Done | tee $LOG I would like to know how to set the Pre-Processing properly. Tanks!! I set the conditions as follows: SOLUTION MODELLING Time: Transient Flow: Compressible Turbulence: RANS - Standart k-E Thermal: NO Buoyancy (Empty) MATERIALS See the picture BOUNDARY CONDITIONS front Patch Type: Wall Momentum: Type: Fixed Wall Wall Type: No Slip Thermal: Type: Zero Gradient back: Patch Type: Wall Momentum: Type: Fixed Wall Wall Type: No Slip Thermal: Type: Zero Gradient porosity wall: Patch Type: Wall Momentum: Type: Fixed Wall Wall Type: Slip Thermal: Type: Zero Gradient inlet: Velocity: Velocity Type: Mass Flow Rate Inlet Mass Flow Rate: 0.1 Kg/s Pressure: Pressure Type: Zero Gradient Turbulence: Type: By Turbulence Intensity and Mixing Length Turbulence Intensity: 0.05 Mixing Length: 0.005 m Thermal: Type: Fixed Temperature Temperature: 293 K outlet: Velocity: Velocity Type: Pressure Inlet Outlet Velocity Pressure: Pressure Type: Fixed Value Pressure: 100,000.0 Turbulence: Type: Inlet Outlet k: 1 Epsilon: 200 Thermal: Type: Inlet Outlet Temperature: 293 K SOLVER SETTINGS Non-Orthogonal Correctors: 0 Rho Min: 0.5 Rho Max: 2 Relaxations Factors: U: 0.7 p: 0.3 k: 0.7 epsilon: 0.7 T: 0.7 FIELDS INITIALISATION U: 0 0 0 p: 100,000.0 k: 1 epsilon: 200 T: 293 RUNTIME CONTROLS Start From: Star Time 0 End Time: 10 Delta t: 1 Adjustable Time Step: NO Write Control: Time Step 1 Write Compression: Uncompressed Time Format: General Time Precision: 6 Graph Format: Raw |
November 13, 2014, 00:38 |
Abhijit
Rep Power: 11 |
I get the same error, did you figure out what the problem was??? Is it due to the thermoPhysicalProperties or boundary conditions? |
helyxos 2.0, rhopimplefoam |
License trouble: ANSLIC_ADMIN, FLEXlm not running, but two lmgrd processes running! | dancoz87 | ANSYS | 17 | November 14, 2016 01:10 |
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running | sunliming | OpenFOAM Bugs | 21 | November 22, 2013 03:38 |
Something weird encountered when running OpenFOAM in parallel on multiple nodes | xpqiu | OpenFOAM Running, Solving & CFD | 2 | May 2, 2013 04:59 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
