"Rotating patches" for dynamic mesh
Old   July 28, 2014, 10:42
Default "Rotating patches" for dynamic mesh
Lisandro Maders
Lisandro Maders is on a distinguished road
I am performing a centrifugal pump simulation. I am using two approaches: MRF and dynamic mesh. My mesh has one cellZone called rotorMRF. However, there are three patches inside this cellZone, and only two of them are actually rotating. There is an option called rotatingPatches to be put inside the MRF definition in which you can select the patches that are actually rotating inside the MRF zone (rotorMRF). Therefore, for the MRF approach it is allright.
Now, for the dynamic mesh, I don't have the option rotatingPatches to select which are the regions inside the cellZone that I want to be rotating. The dynamicMeshDict file only allow me to select a cellZone (or maybe not, but I didn't find the solution), but doing this there will be a rotating region that should not be doing it.
I tried to find some utility to split a cellZone into other cellZones, but also was not able to find it..
Any ideas of solution?
I appreciate any help. Thanks!
Lisandro
Lisandro Maders is offline   Reply With Quote
rotating patches dynamic
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
