output for snapping process
Old   August 21, 2014, 05:37
Default output for snapping process
M. C.
student666 is on a distinguished road
Hi all,
I would like to know if there's a chance to have the scaling iteration of the smoothing process as output into csv format or formatted txt.
thank you for supporting.
Regards
Smoothing iteration 3
Found 0 non-mainfold point(s).
Scaling iteration 0
Moving mesh using displacement scaling : min:1 max:1
Checking faces in error :
non-orthogonality > 45 degrees : 326
faces with face pyramid volume < 1e-13 : 0
faces with face-decomposition tet quality < 1e-09 : 0
faces with concavity > 70 degrees : 1
faces with skewness > 2 (internal) or 15 (boundary) : 0
faces with interpolation weights (0..1) < 0.02 : 0
faces with volume ratio of neighbour cells < 0.01 : 0
faces with face twist < 0.02 : 0
faces on cells with determinant < 0.001 : 0
Scaling iteration 1
Moving mesh using displacement scaling : min:0.75 max:1
non-orthogonality > 45 degrees : 229
Scaling iteration 2
Moving mesh using displacement scaling : min:0.5625 max:1
non-orthogonality > 45 degrees : 102
student666 is offline   Reply With Quote
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 06:16
RNG diverged during the analysis the flow over a multi element airfoil, why? s.m OpenFOAM Running, Solving & CFD 0 August 5, 2013 08:39
HTC variation output in quenching process mechanical AVL FIRE 2 September 14, 2012 11:21
How to output the process of the calculation ivanyao OpenFOAM Running, Solving & CFD 10 March 2, 2009 05:46
