How to setup initial pressure for an ABL buoyantBoussinesqSimpleFoam simulation
Old   September 24, 2014, 08:27
Default How to setup initial pressure for an ABL buoyantBoussinesqSimpleFoam simulation
Leonardo Oliveira
leonardo.oliveira is on a distinguished road
Hello Foamers,
I have started to use OpenFOAM this year, and right now I'm trying to use it to perform an ABL simulation considering the temperature effects, so a decide to use the buoyantBoussinesqSimpleFoam solver.
The simulation consists in a flat terrain with a Box in the middle, the top BC is 310K hot and the rest (inlet, outlet, sides, ground and Box) is 283k.
The U in the inlet is a log prifile made with the ABLconditions file (took from the turbineSiting tutorial).
When I start the solver it start the calculations but, for some reason that I don't know, the time step continuity errors goes up high and the simulation stops with a "floating point exception". I think this has to be with the BC (correct me if I'm wrong).
So I have some questions:
1. How am i supose to setup the initial "p_rgh" file?
2. The "p" file is really needed?
Thanks in advance.
Sorry for the bad English.
Leonardo Oliveira.
leonardo.oliveira is offline   Reply With Quote
Old   November 20, 2014, 11:17
Euler is on a distinguished road
Could you solve the problem? I have the same problems.
Euler is offline   Reply With Quote
abl flow, buoyantboussinesqsf, p_rgh, temperature bc
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 12:50
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
