kOmegaSST wall functions and mass inlet boundary
Old   February 4, 2015, 05:58
Default kOmegaSST wall functions and mass inlet boundary
Frans Visscher
FransVisscher is on a distinguished road
Dear CFD'ers,
For my master Thesis I have to model an semi-confined jet, starting from the flat plate to and later on extend the model to an bend and multiphase. However I am currently struggling with the kOmega (SST in particular) I have noticed the following things:
The automatic wall functions for the kOmegaSST is calculating the dissipation omega as
w = sqrt((w_vis)^2+(w_log)^2)
which are given in Menter's publications. I found this verification in the wall function source code (the only one available in OF 2.3.x for omega for incompressible flow). So assume the wall function must be specified separately.
The source code for the turbulence model however also indicates that it uses the modification by Hellsten to account for rough walls using the extra blending factor F3. Now here comes my first problem: why is the omega wall function than not equipped with the rough wall condition given i believe at first in Wilcox's paper as:
w=(u_tau^2/nu)*S_R
where u_tau is the friction velocity, nu is kinematic viscosity and S_R is a factor dependent on the non dimensional equivalent grain size?
Secondly, how can I specify the mass injection boundary condition for omega at my inlet as suggested also by Wilcox:
w=(u_tau^2/nu)*S_B
where S_B is a factor depending on the normal velocity at this surface in a non dimensional form defined as v_n+=v_n/u_tau
Note: w stands here for omega
Now of course I can start coding myself but that would take me more time than I probably have for this 'introduction problem' and it will astonish me when these functions are never been missed before in OF by others (if they really are not part of it). So does anyone have an answer?
Thanks in advance!
FransVisscher is offline   Reply With Quote
boundary, komegasst, menter, omega, wilcos
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
