How to set up MRFsimpleFoam cellzones
Old   December 16, 2015, 05:01
Default How to set up MRFsimpleFoam cellzones
Anonymous
tagabi3 is on a distinguished road
I am trying model an MRF problem, but I am stuck at how to set properly the cellZones and other sets. So far I have done the mesh with blockMesh and snappyHexMesh. Then I use topoSet to set the cells, which should be the rotating zone, the following way:
actions
        name    mrffan;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
box (-0.12 -0.002 -0.21) (0.12 0.012 0.021); //box which contains the fan
        name    mrffan;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set mrffan;
Where the fvOptions is set the following way:
MRF1
    type            MRFSource;
    active          true;
    selectionMode   cellZone;
    cellZone        mrffan;
    MRFSourceCoeffs
        active      true;
        origin      (0 0 0);
        axis        (0 1 0);
        omega       100;
When I execute simpleFoam it does 5-6 iterations and then it diverges. Can anyone please give me a step by step guide on how to set the rotating zone? And also how to set the stationary zone, because I have read somewhere, that it should be set as well. I am sending a minimum working example with the mesh without topoSet being exectued.
https://drive.google.com/file/d/0B11...ew?usp=sharing
Thank you in advance!
Gabor
tagabi3 is offline   Reply With Quote
[mesh manipulation] mirrorMesh and undoing the joining of patches chegdan OpenFOAM Meshing & Mesh Conversion 3 October 21, 2015 08:09
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
problem of four patches set to cyclic boundary bryant_k OpenFOAM 9 September 22, 2013 12:42
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 04:18
