Basic AMI question - interface shape
Old   January 8, 2016, 03:24
Default Basic AMI question - interface shape
akidess's Avatar
Anton Kidess
I would like to simulate a rotor which is tightly encapsulated by a stator with the shape depicted in the attached image. I'm guessing I can't use a single AMI interface due to the kink. Is that assumption correct? Can I circumvent the problem using two AMI interfaces - one for the top, and one for the bottom part of the rotor?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 8, 2016, 08:40
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Sorry, can you show axis of rotation on your sketch?
mkraposhin is offline   Reply With Quote
Old   January 8, 2016, 09:10
akidess's Avatar
Anton Kidess
Yeah, I should have included that I added the rotation axis to the figure. I didn't draw it 100% proper, but it should be symmetric around that axis.
Old   January 8, 2016, 09:30
mkraposhin's Avatar
Matvey Kraposhin
Ok, now i see (or i think that i see).
I don't see any barriers to use single AMI interface. After 3 years of experience with AMI, we found next two requirements that should be satisfied:
1) Rotor and Stator surfaces should match each other exactly (at least at the level of CAD geometry)
2) Rotor and stator must be meshed with as much as possible uniform grids with approximately same length of of edges
Old   January 8, 2016, 10:38
akidess's Avatar
Anton Kidess
Great, thank you for your hints!
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
volume conservation and accurate interface shape Prosper OpenFOAM Running, Solving & CFD 9 May 14, 2015 09:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
