Free Surface Problem
Old   January 8, 2016, 18:17
Default Free Surface Problem
talat gokcer
talatgokcer is on a distinguished road
Hello Everyone,
I want to make a simulation two phase ship flow simulation on OpenFoam. I did my test simulation on OpenFoam DTC tutorial. I generated a mesh on snappyHexMesh and run setFields. My initial free surface condition is not that i want. There are nonsense surface elevations. What shall i do in order to make it better?
Thanks
talatgokcer is offline   Reply With Quote
Old   January 8, 2016, 18:19
talat gokcer
Here is my snapshot
Old   January 8, 2016, 18:21
talat gokcer
and my dict files
freesurface.zip
Old   January 9, 2016, 08:52
Pascal Balz
pbalz is on a distinguished road
this could be a mesh effect.
Is your alpha 0.5 contour perfectly flat?
Sometimes it can be beneficial to use a small offset in your setFields value, i.e. 0.245 instead of 0.244.
If this doesn't work try meshing with high aspect ratio cells (so "flat" cells, as in the DTCHull tutorial) at your water surface. This should yield a better z-wise resolution so that setFields picks the right cells.
Regards,
Pascal
pbalz is offline   Reply With Quote
Old   January 9, 2016, 10:04
talat gokcer
Hi Pascal,
No, it's my 0.5 alpha contour unfortunately. I'm going to try your advices. However, in high aspect ratios snappyhexmesh is challenge. I should play refinement boxes for that. Thank you
freesurface
problem of Free surface profile mina00 FLOW-3D 0 October 20, 2014 16:07
free surface problem with open channel alidogrul Fluent Multiphase 0 August 26, 2013 14:25
Melting and solidification with free surface problem? cqlwj123 CFX 6 July 25, 2013 02:46
Stir in a bowl : free surface problem JohnAB STAR-CCM+ 19 March 8, 2013 13:11
How to plot the wave contour in ship flow (free surface) problem deddy1973 CFX 6 February 19, 2013 05:49
