January 15, 2016, 06:12 |
Mesh refinement regions with snappyHexMesh
AndreiCFD
Rep Power: 13 |
Hi all,
I would like to know if in snappyHexMesh, refinement regions can be specified based on the locations that I want? For example I have a terrain map with some wind turbines. I have 20 turbines and I would like to refine the regions around my wind turbines in order to capture the wake? Is such a thing possible in snappyHexMesh? I would appreciate any help and many thanks. Cheers, Andrei |
January 15, 2016, 13:48 |
Nima Samkhaniani
Rep Power: 24 |
yep its possible you define inside/outside or distance from an specific region then it refines it
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
January 15, 2016, 13:53 |
Marc
Rep Power: 13 |
Hey,
have a look at the tutorials, especially for the incompressible/pimpleDyMFoam/wingMotion/wingMotion_snappyHexMesh/system/snappyHexMeshDict. There you can find an example for refine your surface (refine any patch field) and how to define an block as refinement region. |
January 15, 2016, 15:18 |
AndreiCFD
Rep Power: 13 |
Thanks guys. I'll have a look at the tutorials.
January 25, 2016, 07:58 |
gereksiz
Rep Power: 11 |
Take a look at this tutorial
tutorials/incompressible/simpleFoam/turbineSiting I think it's exactly what you want. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 05:26 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 14:46 |
[snappyHexMesh] snappyHexMesh refinement regions ignored | guitarbren | OpenFOAM Meshing & Mesh Conversion | 2 | April 9, 2013 03:59 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
