using chemkin
Old   December 15, 2014, 14:30
Default using chemkin
Josh Dawson
JMDag2004 is on a distinguished road
Hello everyone! I'm attempting to use chemkin but I'm getting the following error:
jmdag1981@jmdag1981-Gazelle-Professional:~/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR$ blockMesh
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.3.0-f5222ca19ce6
Exec : blockMesh
Date : Dec 15 2014
Time : 13:23:09
Host : "jmdag1981-Gazelle-Professional"
PID : 5050
Case : /home/jmdag1981/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/jmdag1981/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
Basic statistics
Number of internal faces : 10
Number of boundary faces : 40
Number of defined boundary faces : 40
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 0.46
Block 0 cell size :
i : 0.00248768 .. 0.000497535
j : 0.000685672 .. 0.00205702
k : 0.0046 .. 0.0046
Block 1 cell size :
i : 0.00129373 .. 0.00129373
Block 2 cell size :
i : 0.00126691 .. 0.00190036
j : 0.000533293 .. 0.00159988
Block 3 cell size :
i : 0.00108267 .. 0.00216534
j : 0.000736823 .. 0.000736823
Block 4 cell size :
j : 0.00100004 .. 0.00100004
Block 5 cell size :
i : 0.00043858 .. 0.00131574
Block 6 cell size :
i : 0.000254255 .. 0.000762764
Block 7 cell size :
j : 0.00050048 .. 0.00050048
Block 8 cell size :
Block 9 cell size :
Adding cell zones
0 zoneZero
1 zoneOne
2 zoneTwo
3 zoneThree
4 zoneFour
5 zoneFive
6 zoneNine
7 zoneEight
8 zoneSeven
9 zoneSix
Writing cell zones as cellSets
Writing polyMesh
Mesh Information
boundingBox: (0 0 -0.0023) (0.500002 0.089999 0.0023)
nPoints: 123102
nCells: 60634
nFaces: 243452
nInternalFaces: 120352
Patches
patch 0 (start: 120352 size: 72) name: inletLeftBoundaryZoneZero
patch 1 (start: 120424 size: 208) name: fixedWallsTopBoundaryZoneZero_ZoneTwo
patch 2 (start: 120632 size: 20) name: symmetryPlaneBottomBoundaryZoneZero
patch 3 (start: 120652 size: 60) name: wedgeFaceBottomBoundaryZoneOne
patch 4 (start: 120712 size: 128) name: detonationTubeCasingBottomBoundaryZoneTwo
patch 5 (start: 120840 size: 2) name: backFaceDetonationTubeCasingLeftBoundaryZoneEight
patch 6 (start: 120842 size: 50) name: fixedWallInitiatorTubeTopBoundaryZoneFive
patch 7 (start: 120892 size: 5) name: fixedWallInitiatorTubeLeftBoundaryZoneThree
patch 8 (start: 120897 size: 50) name: symmetryPlaneInitiatorTubeBottomBoundaryZoneFive
patch 9 (start: 120947 size: 128) name: fixedWallDetonationTubeTopBoundaryZoneThree
patch 10 (start: 121075 size: 19) name: fixedWallDetonationTubeLeftBoundaryZoneThree
patch 11 (start: 121094 size: 128) name: symmetryPlaneDetonationTubeBottomBoundaryZoneFour
patch 12 (start: 121222 size: 98) name: outletRightBoundaryZoneSix_ZoneNine
patch 13 (start: 121320 size: 432) name: fixedWallsTopBoundaryZoneNine
patch 14 (start: 121752 size: 432) name: symmetryPlaneBottomBoundaryZoneSix
patch 15 (start: 122184 size: 121268) name: frontAndBack
End
jmdag1981@jmdag1981-Gazelle-Professional:~/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR$ setFields
Exec : setFields
Date : Dec 15 2014
Time : 13:23:16
PID : 5052
nProcs : 1
Create time
Create mesh for time = 0
Reading setFieldsDict
Setting field region values
Adding all cells of cellZone zoneFive ...
Found matching zone zoneFive with 250 cells.
Setting internal values of volScalarField H2
Setting internal values of volScalarField O2
Setting internal values of volScalarField N2
Setting internal values of volVectorField U
Adding all cells of cellZone zoneFour ...
Found matching zone zoneFour with 640 cells.
Adding all cells of cellZone zoneThree ...
Found matching zone zoneThree with 2432 cells.
Adding all cells of cellZone zoneZero ...
Found matching zone zoneZero with 1440 cells.
Adding all cells of cellZone zoneOne ...
Found matching zone zoneOne with 4320 cells.
Adding all cells of cellZone zoneTwo ...
Found matching zone zoneTwo with 9216 cells.
Adding all cells of cellZone zoneNine ...
Found matching zone zoneNine with 31104 cells.
Adding all cells of cellZone zoneEight ...
Found matching zone zoneEight with 864 cells.
Adding all cells of cellZone zoneSeven ...
Found matching zone zoneSeven with 8208 cells.
Adding all cells of cellZone zoneSix ...
Found matching zone zoneSix with 2160 cells.
End
jmdag1981@jmdag1981-Gazelle-Professional:~/OpenFOAM/jmdag1981-2.3.0/run/EAPDR/EAPDR$ reactingFoam
Exec : reactingFoam
Date : Dec 15 2014
Time : 13:23:31
PID : 5053
nProcs : 1
Create time
Reading g
Creating reaction model
Selecting combustion model laminar<psiChemistryCombustion>
Selecting chemistry type
chemistrySolver ode;
chemistryThermo psi;
Selecting thermodynamics package
type hePsiThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
energy sensibleInternalEnergy;
equationOfState perfectGas;
specie specie;
Selecting chemistryReader chemkinReader
--> FOAM FATAL ERROR:
Unknown chemistryReader type chemkinReader
Valid chemistryReader types are:
1(foamChemistryReader)
From function chemistryReader::New(const dictionary&, speciesTable&)
in file lnInclude/chemistryReader.C at line 55.
FOAM exiting
Not sure what I'm doing incorrectly. I've got a chem.inp and therm.dat file respectively in a chemkin folder. I've run through tutorials and searched on this forum but can't find anything regarding this error. Most likely it's an easy fix, I wouldn't be shocked if I am overlooking something very simple. Certainly possible I am being a complete bonehead here! Any help would be greatly appreciated!
JMDag2004 is offline   Reply With Quote
Old   December 15, 2014, 16:38
Josh Dawson
Can anyone help me? I'm not sure if I am posting these questions correctly, maybe there is something else I am doing incorrectly...but I am not getting any response. Even if someone doesn't have the time to give a complete answser, at least a nudge in the right direction maybe? Thanks in advance!
Old   March 8, 2016, 22:38
Thien Xuan Dinh
dinh is on a distinguished road
Hi
It is to late, but please check energy option
dinh is offline   Reply With Quote
chemistryreader, chemkinreader
how to find distribution field of reaction rates when CHEMKIN is enabled? EdgarasM FLUENT 1 February 18, 2019 09:41
creating PDF Table from imported chemkin files idomeneo FLUENT 1 November 2, 2016 05:23
Chemkin - Detonation shrikant96 Main CFD Forum 2 July 19, 2016 04:11
Chemkin Library (CKLIB) juzer_700 OpenFOAM Programming & Development 0 February 20, 2013 00:41
Question on CHEMKIN INTERFACE Rui Yang Phoenics 7 January 30, 2002 04:04
