Backward facing step control with variable inlet
Old   March 16, 2016, 11:06
Question Backward facing step control with variable inlet
chuchosolis21 is on a distinguished road
I am a very new user to OpenFOAM, I am working on the simulation and control of incompressible flow over a backward facing step.
I have managed to run simulations of 'normal' BFS in OpenFOAM, but I would like to run the simulation in the presence of an input defined by me.
This input needs to be variable (more like random noise not sinusoidal for example), and I am not sure how to do this since I tried to use the 'UniformValue' but I think this needs for the entire input sequence to be added before the start of the simulation in a table, whereas when I apply the control the values needed to be applied would be updated at each timestep, so this would not work for me.
Has someone worked on something like this or could you point me in the right direction?
Thanks
chuchosolis21 is offline   Reply With Quote
backward facing step, control, variable inlet
Velocity drop over backward facing step warlocklw CFX 2 February 9, 2012 21:24
air-fuel mixing in backward facing step abdullahkarimi Main CFD Forum 0 March 19, 2011 18:39
Incompressible Navier-Stokes equations for a backward facing step werder85 Main CFD Forum 1 January 3, 2011 16:19
Backward Facing Step with Blowing azar Main CFD Forum 1 November 16, 2006 01:01
Corner Vortex for Backward Facing Step Patrick G. Hu Main CFD Forum 0 August 6, 2002 09:34
