creating new Patches using topoSetDict
Old   April 19, 2016, 16:09
Default creating new Patches using topoSetDict
Lorenzo
Lorenzo92 is on a distinguished road
Hello everyone,
I need to create a patch from a given mesh. I can visualize the mesh in paraview and I can keep trace of the cells label ( or number ) in this enviroment, which afterwards I'd like to use to generate the new patch.
My problem is then how to implement that in openFoam by using the topoSetDict.
Can anyone suggest me ho to set the dictionary? My only mean is the list of the cells , which are going to make up the patch.
Thanks
Lorenzo92 is offline   Reply With Quote
Old   April 19, 2016, 16:53
Alex
Kina is on a distinguished road
Hi Lorenzo,
maybe this is useful for you!
http://www.cfd-online.com/Forums/ope...reate-new.html
Cheers
Alex
Kina is offline   Reply With Quote
Old   April 20, 2016, 03:11
Lorenzo
Thnaks for the suggestion, I followed the entries in the dictionary you pointed me out , in particular :
{ name jetCells; type cellSet; action new; source cylinderToCell; sourceInfo { p1 (0 0 0); p2 (0 0 1); radius 0.0018; } } { name jetFaces; type faceSet; action new; source cellToFace; sourceInfo { set jetCells; option all; } }and I costumized it according to my needs :I just changed the name of each set (jetCells --> c0 and jetFaces --> f0) and using labelToCell instead of cylinderToCell for the first set , specifying in this entry the cell labels I got through paraview .
When I type topoSet in the command line I would expect as a result the creation of a folder "sets" under constant/polymesh/sets . Within this folder "sets" only the cellSet c0 is present , while f0, ( that should have been created as faceSet from the cellSet c0 ) is missing.
This brings about problems when I run createPatch since the patch I would like to create need the missing faceSet f0.
I can show you my topoSetDict for more clearness:
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
name c0;
type cellSet;
action new;
source labelToCell;
sourceInfo
value ( 0 1 2 3)
name f0;
type faceSet;
action add;
source cellToFace;
sourceInfo
set c0;
option all;
Can you find out where I wrong?
Old   April 20, 2016, 03:17
Antimony is on a distinguished road
For the faceSet, is there a reason why the action is "add" instead of "new"? I don't see a previous definition for "f0", so am curious as to why the action stated is "add".
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   April 20, 2016, 03:32
Lorenzo
Hi Antimony,
I think it was my mistake, btw I changed it in new as mentioned. Still the problem is there. It seems the action on f0 is not being read at all .
Old   April 20, 2016, 03:41
You are missing a semi-colon after "value (0 1 2 3)"...
Cheers,
Antimony
Old   April 20, 2016, 17:06
Lorenzo
Ok, fixed .The semi-colon was missing.
Thanks a lot!!!
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 23:35
Courant number, patches, etc oort OpenFOAM 1 July 24, 2009 19:05
