Visualizing initial setup
Old   May 19, 2016, 17:18
Default Visualizing initial setup
anonymous
cute is on a distinguished road
I created a 3D mesh with some initial setup.
Mesh Dimension: 0.1 x 0.1 x 0.5 m^3
Initial data is setup at the center of the bottom part with height of 0.4
I used setFields witt BoxToCell to initialize my grid. When I visualize in paraview with wireframe, it only shows my initial data at the bottom plane (i.e. z=0). I also noticed that wireframe only display wires on surfaces but not internally. I thought that might be a problem.
I also tried to visualize with surface and still the result is same after setting opaque property to 0.3.
Could you please explain, what I am doing wrong? and How can I visualize my setup?
Thanks.
cute is offline   Reply With Quote
Old   July 26, 2016, 11:05
HenningW is on a distinguished road
Did you try to put a slice trough your domain and have a look that way? Also, which objects did you select for your Mesh Region?
HenningW is offline   Reply With Quote
Old   July 26, 2016, 11:12
anonymous
Thanks, I solved the problem by adding slice filter.
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 17:36
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
